I have OSMC RC3 0.9.9 updates 5 minutes ago (on my Raspberry PI2) but i have this problems… on Installation Source for zip addons in the list it’s present a SMB source (192.168.1.210) and i don’t figure how it’s possibly to remove it!
I have try to found it on “File Manager” but there’s no source here… i have tryed to use C on keyboard for context menù for modify it or similar but apparently there’s no mode to delete it…
If it’s possibly help me…
I can also try, if someone can post me a suggestion, try to modify some file by pc using telnet or similar…
This is the main problems… on my LAN 192.168.1.210 it’s no more present:
I don’t remember how i can add this source here… but now i choose:
Home -> Preferences -> Add-ons -> Install from zip
Now it’s present the default value:
Browser zero conf
Home
etc etc
At end of this list i don’t know how i have add this and i have:
smb://192.168.1.210
If i press enter on it… i obtain error on host… at this point from main list i have tryed to deleted it but i can’t…
EDIT
On OSMC i have installed and now it’s running the FTP Server… now i can access to my Rasp from my PC using filezilla:
If you can suggest to me what’s the exact file it’s stored this configuration i thinks i can try to edit manually from pc…
It won’t hurt anything. If it wasn’t config’d in sources.xml (file manager) then I’d chalk it up to the borked implementation of SMB between Windows and Linux that have been present forever…
mmmmmmmmmmm… this is the file.
192.168.1.2 it’s my pc… and this is the smb for video section… the shadowcrew it’s a source i have add by file manager and there is appared from “Install from zip” correctly but this “smb://192…210” it’s no present.
I don’t remeber how i have add this… at this point or i need to force a refresh or sources for similar operation…
Go ask http://forum.kodi.tv what populates mediasources.xml because I don’t know. The IP is certainly on your subnet… Possibly by coincidence, but alas…
Sure you can delete the file. But it’s quite possible restarting Kodi will cause Kodi to re-create it.
