Hello (first of all, sorry for my bad english…),
Is it possible disable the autostart of Hyperion ?
To explain myself, I use Hyperion on a Raspberry with OSMC and my
Philips Hue. Hyperion works perfectly, and I can enable or disable
Hyperion using my TV remote (thanks to this tuto How to: turn Hyperion on/off using your TV remote. | nadnerb.co.uk ).
However, I would like to prevent Hyperion to automatically starts
with OSMC (to prevent my Hue to change their color or to switch on
during the “boot sequence”), and I would like to manually starts
Hyperion with the Remote just when I want to use it (in launching the
.sh init.d script…?).
I did not manage to do this. Any help ?
Thank you !
Toast
20 July 2015 14:19
2
systemctl stop hyperion
systemctl disable hyperion
Thank for your answer.
If I use these commands, the service (Hyperion) will be disabled until the next reboot ? Or until I manually restart it ?
Toast
20 July 2015 15:26
4
disable is disable then its turned off permanently
stop is until next boot
for more info google systemctl command
I have this error message when I try to disable Hyperion
update-rc.d: error: hyperion Default-Start contains no runlevels, aborting.
Do you know why ?
Thank you
Probably the wrong service name. Make sure you are using the correct name for the service.
Toast
20 July 2015 17:40
7
no idea why, for me it works without issues
make sure that hyperion installed correctly
It’s OK. It seems that I had a problem with symbolic links…
I just reinstalled Hyperion and follow this tuto Home · hyperion-project/hyperion Wiki · GitHub , and now it works perfectly.
Thank you very much !
