RetroPIE / RetrOSMC ALSA Sound Issue - Sound Card not found
Hello guys,
I’ve been at this problem for a few nights now, so any help would be worthy of a bronze statue in your likeness.
I’m running RetrOSMC, which is a RetroPie installation built into OSMC ([HowTo] RetroPie and OSMC: Retrosmc - Retrogaming on OSMC).
I’m using a Raspi 2, everything is up to date. Sound works fine in OSMC, but I get no sound in RetroOSMC. I’ve re-flashed / re-installed a couple of times, same results.
I’ve tried setting options in /boot/config.txt such as hdmi_drive=2, but I’m confident that this isn’t the problem. When I run any emulators, it runs without sound and I get stuff like this in the log:
PPU.RenderSub = 0 PPU.FullClipping = 1 Settings.Transparency = 1 Settings.SpeedhackGameID = 7 PPU.SFXSpeedupHack = 0 coldata_update_screen = 0 ALSA lib confmisc.c:768:(parse_card) cannot find card '0' ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory ALSA lib confmisc.c:1251:(snd_func_refer) error evaluating name ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory ALSA lib conf.c:4720:(snd_config_expand) Evaluate error: No such file or directory ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM default
I’ve tried using sdl instead of alsa, same result.
When I run cat /proc/asound/cards , I get:
It looks like alsa isn’t recognizing my sound hardware?
I generated a log of my alsa settings:
    !!ALSA Information Script v 0.4.64
    !!Script ran on: Sat Dec  5 18:11:08 UTC 2015
    !!Linux Distribution
    ID_LIKE=debian
    !!DMI Information
    Manufacturer:
    Product Name:
    Product Version:
    Firmware Version:
    !!Kernel Information
    Kernel release:    4.3.0-10-osmc
    Operating System:  GNU/Linux
    Architecture:      armv7l
    Processor:         unknown
    SMP Enabled:       Yes
    !!ALSA Version
    Driver version:     k4.3.0-10-osmc
    Library version:    1.0.28
    Utilities version:  1.0.28
    !!Loaded ALSA modules
    !!Sound Servers on this system
    No sound servers found.
    !!Soundcards recognised by ALSA
    --- no soundcards ---
    !!Modprobe options (Sound related)
    snd_pcsp: index=-2
    snd_usb_audio: index=-2
    snd_atiixp_modem: index=-2
    snd_intel8x0m: index=-2
    snd_via82xx_modem: index=-2
    !!ALSA Device nodes
    crw-rw---- 1 root audio 116,  1 Dec  5 12:40 /dev/snd/seq
    crw-rw---- 1 root audio 116, 33 Dec  5 12:40 /dev/snd/timer
    !!Aplay/Arecord output
    APLAY
    aplay: device_list:268: no soundcards found...
    ARECORD
    arecord: device_list:268: no soundcards found...
    !!Amixer output
    !!Alsactl output
    --startcollapse--
    --endcollapse--
    !!All Loaded Modules
    Module
    snd_bcm2835
    snd_pcm
    snd_timer
    snd
    8021q
    garp
    stp
    llc
    bnep
    sg
    uinput
    uas
    btusb
    btrtl
    btbcm
    btintel
    bluetooth
    evdev
    joydev
    rfkill
    lirc_rpi
    bcm2835_thermal
    lirc_dev
    rc_core
    bcm2835_gpiomem
    bcm2835_wdt
    uio_pdrv_genirq
    uio
    fuse
    ipv6
    !!ALSA/HDA dmesg
That’s all the information that I know how to collect, but I’ll share any logs or configs that might be relevant. I’d greatly appreciate any help that you guys can offer.
dtparam=audio=on to config.txt and it should work
Dude YEAH!
Thanks, that worked. Toast, you rock and I am so damn happy right now man.
I’ve had the exact same problem starting a couple of weeks back, I don’t know if it was an update or something, but audio stopped working overnight in RetroPie. I tried adding dtparam=audio=on to both config.txt (/boot and /opt/retropie/boot) but it doesn’t work. I uninstalled / reinstalled RetroPie, still doesnt work. Any clues ?
runcommand.log:
ALSA lib confmisc.c:768:(parse_card) cannot find card ‘0’
I did a fresh install two days ago, sound works here with dtparam=audio=on in config.txt
Fixed! I used OSMC’s pi config editor to add the line via their Kodi addon and it worked. Thanx!
