Retrosmc installation
I followed the guide to install Retrosmc. Everything was going fine and then I checked Putty and it said that it was forced to close due to an error (sorry it flashed up to quickly for me to notice it).
The last thing it says on Putty is:
Preparing to unpack …/libsamplerate0-dev_0.1.8-8_armhf.deb …
Unpacking libsamplerate0-dev:armhf (0.1.8-8) …
The Putty Window status is Inactive.
Should I try and uninstall and reinstall… Conscious not to make things worse…
2 posts were merged into an existing topic: [HowTo] Retrosmc - Retrogaming on OSMC
