Uploaded my logs: http://paste.osmc.io/ikawepapud
Here’s the mediainfo output for the file I testing to generate the logs, but to be clear this has happened with other file-types/codecs as well:
General
Complete name : [REDACTED]
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 496 MiB
Duration : 51mn 12s
Overall bit rate : 1 355 Kbps
Encoded date : UTC 2017-03-20 03:30:56
Tagged date : UTC 2017-03-20 03:30:56
gsst : 0
gstd : 3072580
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 51mn 12s
Bit rate : 1 161 Kbps
Maximum bit rate : 12.0 Mbps
Width : 1 280 pixels
Height : 718 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.053
Stream size : 425 MiB (86%)
Tagged date : UTC 2017-03-20 03:31:19
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 51mn 12s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 202 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 70.3 MiB (14%)
Title : IsoMedia File Produced by Google, 5-11-2011
Language : English
Encoded date : UTC 2017-03-20 03:31:09
