Hello guys,
Regarding the RBG range limited or full. What is your take on this.
You can read on some forum the correct combinaison of ranges among the content, gpu and display.
I have a Panasonic OLED, I always watched with Kodi RGB at limited and my TV set to limited as well, and everything seems fine.
Tho, a friend questioned my settings saying it may not be the optimal picture quality setting depending on how the GPU is set, limited or full, to have the least conversions possible in the signal path.
On a computer it is easy to see in graphic card settings what the GPU is doing, but on the Vero 4K+ box, all you have is the Kodi and the TV setting, can’t do anything with the GPU driver settings, at least without going into console to check it out.
So my question is, which setting is the best in Kodi video settings and on the TV as well ?
My understanding is that no Blu-ray or consumer video sources is full range anyway, so by setting it to limited, I’m ok.
If I was on the computer, I would let the GPU at full, because you do not what the GPU to alter incoming source and then the TV to alter it again after. But I don’t know what the Vero 4k+ box do.
What are your settings ?
Thank you !
