Hello ,
Following to a mistake in the /etc/fstab ( nfs mountage added), i can’t anymore access my system.
On the console , the following message appears : give root password for maintenance or type Control-D to continue.
But Control-D don’t do anything…and I try a a lot of password but no one works…
I can’t anymore access the system via ssh.
Could you please send me th root password?
Or are there a way to reaccess my system and modify my fstab.
You would need to put the SD card into another Linux system to edit it.
If you don’t have Linux on a PC, one way of doing this is if you had another install of OSMC on another SD card that you could boot from, you could put your original SD card into a USB SD card reader and connect it to the Pi to access it, where it would be mounted under /media. You could then edit the file, shut down and swap the card back over.
