RP 2 to 3 B+?
I have OSMC on my RPi 2 and I would like to buy the model 3 B+
Do I need to make a new installation or can I put my SD directly on the 3 B+ ?
Thx !
You can swap the SD over.
Just make sure your OSMC is up to date first.
Ok good, but do I have to check something else ?
For example I overclocked my perfs.
My config.txt
gpu_mem_1024=320
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
decode_MPG2=
#Disable for good the ACT LED.
  dtparam=act_led_trigger=none
  dtparam=act_led_activelow=off
#Disable for good the PWR LED.
  dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=off
#arm_freq=1000
#core_freq=450
#sdram_freq=450
#over_voltage=2
arm_freq=1000
core_freq=500
over_voltage=2
sdram_freq=500
Why check ? upadte is auto anyway
