hello i have buy from aliexpress this adapter
https://www.aliexpress.com/item/1200Mbps-2-4GHz-5-8GHz-Dual-Band-Wireless-USB-Wifi-Adapter-Wifi-USB-Dongle-Network-LAN/32647952730.html?spm=a2g0s.9042311.0.0.KX5BBv
i found and istall the drivers for my pc with ubuntu from here http://www.szedup.com/support/driver-download/ep-ac1601-driver/
i want to install to my rp2 with last update
anyone help me
i have try all solution find at net but no one make the adapter work
thanks
The driver is already included. You may need to force match the VID/PID so that the driver is loaded
you can help me do this because I do not know how
Well start with finding out you VID/PID by using lsusb for usbutils
sudo apt-get install usbutils
lsusb
The VID/PID is what is written behind “ID:”
Bus 001 Device 007: ID 0e8d:7612 MediaTek Inc.
If you are sure it runs with mt7610 than:
unplug device
sudo -i
modprobe mt7610u_sta
echo 0df6 0075 > /sys/module/mt7610u_sta/drivers/usb:rt2870/new_id
plug device
nothing happen
reboot and nothing
at first post have all i find of this dongle
i have post and linux driver withi this driver my pc recornized and connect corect…
nothing else to try?
eric_kous:
reboot and nothing
Don’t reboot! This change only works till you reboot.
Provide URL of grab-logs -J -K after you have followed above steps.
Provide lsmod and dmesg output from your PC
So seems driver is mt7662u_sta not mt7610u_sta
So your mission need to be to get mt7662u compiled on OSMC
can you help me
i don’t know how…
eric_kous:
can you help me
i don’t know how…
Sorry that is outside of my league
