System: Linux osmc 4.19.55-6-osmc #1 SMP PREEMPT Sun Nov 3 22:15:28 UTC 2019 armv7l GNU/Linux
I try to configure my remote SAMSUNG AK59-00148A but i encounter an issue when i recording the keys with irrecord.
$ mode2 -d /dev/lirc0
pulse 542
space 1465
pulse 546
space 1469
pulse 540
pulse 119002
$ irrecord -d /dev/lirc0 ~/remote.conf
Press RETURN now to start recording.
Found const length: 120493
Please keep on pressing buttons like described above.
Space/pulse encoded remote control found.
Signal length is 77.
Found possible header: 4571 4467
Found trail pulse: 551
No repeat code found.
Signals are space encoded.
Signal length is 37
Now enter the names for the buttons.
Please enter the name for the next button (press <ENTER> to finish recording)
KEY_0
Now hold down button "KEY_0".
Something went wrong. Please try again. (9 retries left)
Something went wrong. Please try again. (8 retries left)
Something went wrong. Please try again. (7 retries left)
I found this topic so I patched/compiled locally the LIRC Libraries and tools to use a fixed irrecord but I still have the error.
My ir receiver reference is TSOP2238 - 38kHz. Plugged on GPIO 18. Here my settings in osmc.
As I said, I just proceeded to local compilation and patching of the lirc lib for test only. So the lirc lib and tools used by the system is unchanged.
I think the whole LIRC package may need to be replaced.
You could try building the armv7-lirc-osmc package with the patch you referred to and see if this helps. It would also be good to know if we need this patch for recording only and if receiving is otherwise fine. It may be difficult for us to ship this patch included by default as the armv7-lirc-osmc package is shared across other systems.
So, I successfully built and installed the armv7-lirc-osmc from lirc 0.9.4c with the corresponding patches. I was able to create a configuration file with irrecord -d /dev/lirc0 with the devinput driver but not with the default driver.
Anyway, once the remote config file is selected and the two services up (eventlircd and lircd_helper@lirc0), it seems that my remote controller is still not recognized. I loose my mind…
Here my remote config file:
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <lirc@bartelmus.de>
# This config file was automatically generated
# using lirc-0.9.4c(devinput) on Sat Jun 13 20:45:19 2020
# Command line used: -d /dev/lirc0 remote.conf
# Kernel version (uname -r): 4.19.122-1-osmc
# Remote name (as of config file): samsung-ak59-00148a
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
# usb dongle? :
# For bundled USB devices: usb vendor id, product id
# and device string (use dmesg or lsusb):
# Type of device controlled
# (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
name samsung-ak59-00148a
driver devinput
bits 56
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 72
pre_data 0x11
gap 29767
toggle_bit_mask 0x0
frequency 38000
begin codes
KEY_OK 0xDD010000001174
KEY_UP 0xD301000000117C
KEY_DOWN 0xDA010000001177
KEY_RIGHT 0xD9010000001175
KEY_LEFT 0xD4010000001177
KEY_BACK 0xD8010000001175
KEY_EXIT 0xDA010000001173
KEY_INFO 0xD301000000117A
KEY_TITLE 0xD4010000001174
KEY_POWER 0xD0010000001177
KEY_NUMERIC_1 0xDB010000001177
KEY_NUMERIC_2 0xD001000000117B
KEY_NUMERIC_3 0xE8010000001165
KEY_NUMERIC_4 0xD3010000001171
KEY_NUMERIC_5 0xE201000000116D
KEY_NUMERIC_6 0xD5010000001183
KEY_NUMERIC_7 0xD101000000117A
KEY_NUMERIC_8 0xD601000000116B
KEY_NUMERIC_9 0xD5010000001172
KEY_NUMERIC_0 0xD4010000001178
KEY_PLAY 0xCE010000001173
KEY_PAUSE 0xF0010000001156
KEY_STOP 0xDC010000001171
KEY_HOME 0xD8010000001172
end codes
end remote
Same issue with an another remote. I can create a configuration file with irrecord -d /dev/lirc0 but the remote is not recognized. I don’t understand what is wrong.
Are you perhaps testing for recognition when the services and Kodi are running? You would need to stop eventlircd and Kodi to test on the command line.
