I’ve used the new OSMC installer to create a micro sd card for RPi 2.
It seems to boot fine, command lines run up, I get to a screen when it says someting about the 4 processors and then it ends. Screen flashes, TV says no input signal…
I can SSH to the Pi2 so it works.
I’ve tried HDMI_SAFE=1 in config.txt, but did not help.
Just to make the story complete, I’ve used SDformatter to format the SD card before the 4th install, which worked.
Probably there was an error on the sd card OSMC installer could not fix.
I have an issue which sounds somehow similar with this title…
my always on rpi 2 running alpha 4 is working fine unless, I do a reboot while my tv is off, then I get no signal when I turn on my tv.
To fix it at the moment I just do a reboot with the tv on, then all is fine.
Is this feature or bug?
I mean is by purpose to not start kodi when the tv is off?
This is a common issue because the Pi needs to read the EDID data from the TV at boot time, but some TV’s don’t provide this information if the TV is in standby while some do. The solution is to save and enable use of an edid.dat file:
@DBMandrake, what option in the Pi Config menu does this? I’d rather use the “official” method if i can.
update: i used “store_hdmi_to_file” and it created the edid.dat file, then i used “hdmi_ignore_edid” expecting it to update the config.txt file, but it did not do so.
@ActionA yes, that was what i was expecting to be added to the config.txt file automatically when using the Pi Config GUI menu option hdmi_ignore_edid. However, i had to manually add them (so far, i can’t tell what the hdmi_ignore_edid option does). All is working as exptected (after manually adding the config lines to the config.txt file), but i wanted to know what @DBMandrake meant by “automated”… having to manually edit the config.txt file to add these two configuration options doesn’t seem automated. I’m thinking i’m doing something wrong, but don’t know what. Also, these configuration options don’t exist in the Pi Config menu options (that is, there is no hdmi_edid_file or hdmi_force_hotplug options on the Pi Config menu).
All is working fine, i just wanted to clarify, possibly helping someone else get to the fix faster with less ambiguity.
Thanks guys for all you do for the OSMC community!
