Rpi 4 architecture armhf instead of arm64
I did a fresh install of OSMC with 2021-08.1 on raspberry pi 4.
I had some issues installing docker containers becouase the dpkg achitecture says its armhf instead of arm64/aarch64.
Changing the repo an install for docker in apt fixed. But would be nice to have this correct by default
Code:
osmc@osmcumbrel:~$ dpkg --print-architecture
armhf
The Pi 4 OSMC image is multi-architecture, like the Vero4K/+: user space is armhf and the kernel is arm64/aarch64.
dpkg runs in user space as a 32-bit armhf binary and, AFAIK, the architecture is built-in to the installed package. So the “foreign” architecture is arm64, as running dpkg --print-foreign-architectures will confirm.
Thabks. When i explicitly tell dpgk to install an arm64 package,bit installs as I want it.
So you’re explanation brought me to the solution.
Hi cjvanzwol, could you please share your solution?
I have issues with docker on rpi4 like no networking in ubuntu container etc.
`docker info | grep Architecture
Architecture: aarch64
docker inspect ubuntu
“Architecture”: “arm”,
“Variant”: “v7”,
I suppose it is because of architecture mismatch.
Update: I have figured it out, there is an arch definition in repo link. Now it works, thanks for the idea.
I added the arm64 repo:
deb [arch=arm64] https://download.docker.com/linux/debian buster stable
to /etc/apt/sources.list.d/docker.list
sudo apt update
sudo apt install docker
This should install docker for arm64.
maybe I added :arm64 to the command. Then it would become
sudo apt install docker:arm64
I tried a lot and I’m not sure what exactly wa the sollution. But this seemed to stick.
