I have a Raspberry PI 2 with OSMC. Have an external soundcard attached which works great using alsa. However when using aplay -l to list the soundcards, only the external device is shown eventhough the snd_bcm2835 module is loaded. Is there something hardcoded into OSMC which disables alsa output for the on board chip?
osmc@osmc.hongkong:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
Do you have dtparam=audio=on in you /boot/config.txt?
That didn’t seem to be the case. Added it and all set now.
