RPi.GPIO for LED, Push Button, Relay Module
(Tested on RPi 3)
Install RPi.GPIO
$ sudo su
# apt-get update
# apt-get install python-pip python-dev gcc
# pip install rpi.gpio
(may showed some warnings but will successfully installed)
RPi.GPIO Test
connect ‘LED’:
[pin 39] — [jumper] — [-LED+] — [jumper] — [R100ohm] — [jumper] — [pin 40]
$ sudo su
# python
>>> import RPi.GPIO as GPIO
>>> GPIO.setmode(GPIO.BOARD)
>>> GPIO.setup(40, GPIO.OUT)
>>> GPIO.output(40, 1)
>>> GPIO.output(40, 0)
>>> GPIO.cleanup()
>>> exit()
GPIO.output(40, 1) = LED on
GPIO.output(40, 0) = LED off
GPIO - LED on/off
connect ‘LED’:
[pin 40] — [jumper] — [+LED-] — [jumper] — [R100ohm] — [jumper] — [pin 39]
create python on script:
$ sudo su
# nano /home/osmc/lon.py
add to the script:
#!/usr/bin/python
# connect RPi numbered pin
led = 40
GPIO.setup(led, GPIO.OUT, initial=1)
create python off script:
# nano /home/osmc/loff.py
add to the script:
#!/usr/bin/python
# connect pins
led = 40
# pins setup
GPIO.setup(led, GPIO.OUT)
GPIO.output(led, 0)
GPIO.cleanup()
change files permision:
# chmod +x /home/osmc/*.py
LED on:
# /home/osmc/lon.py
LED off:
# /home/osmc/loff.py
GPIO - Push Button + LED
connect ‘push button’:
[pin 33] — [jumper] — [push button] — [jumper] — [pin 34]
connect ‘LED’:
create python button script:
$ sudo su
# nano /home/osmc/lflash.py
add to the script:
#!/usr/bin/python
import time
# connect RPi numbered pins and flashing duration
led = 40
button = 33
sec = 0.5
# hide warning
GPIO.setwarnings(0)
# pins setup
GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# wait for button press
print('Wait for button press...')
GPIO.wait_for_edge(button, GPIO.FALLING)
# led flash 3 times then off
GPIO.output(led, 1)
time.sleep(sec)
GPIO.output(led, 0)
time.sleep(sec)
GPIO.output(led, 1)
time.sleep(sec)
GPIO.output(led, 0)
time.sleep(sec)
GPIO.output(led, 1)
time.sleep(sec)
GPIO.output(led, 0)
# clear settings
GPIO.cleanup()
change file permission:
Activate:
# /home/osmc/lflash.py
LED flash:
press button
GPIO - Push Button + Command (e.g. shutdown)
(Note: A remote control with keymaps should be easier than a push button.)
[pin 33] — [push button] — [jumper] — [pin 34]
$ sudo su
# nano /home/osmc/bshutdown.py
add to the script:
#!/usr/bin/python
import os
# hide warning
GPIO.setwarnings(0)
button = 33
# hide warning
GPIO.setwarnings(0)
# pins setup
# activate system command
os.system('sudo shutdown -h now')
Shutdown
# /home/osmc/bshutdown.py
press button
GPIO - Relay Module
connect ‘relay module’ (some pins may glow module LEDs by default)
.[pin 6] — [jumper] — [module GND]
.[pin 35] — [jumper] — [module IN1]
.[pin 36] — [jumper] — [module IN2]
.[pin 37] — [jumper] — [module IN3]
.[pin 38] — [jumper] — [module IN4]
.[pin 4] — [jumper] — [module VCC]
create python relay-on script:
$ sudo su
# nano /home/osmc/ron.py
add to the script:
#!/usr/bin/python
import time
# custom variables
# connected RPi numbered pins
r1 = 35
r2 = 36
r3 = 37
r4 = 38
# delay in seconds
r1delay = 3
r2delay = 1
r3delay = 2
r4delay = 3
on = 0
off = 1
# hide warning
GPIO.setwarnings(0)
# pins setup
# set pin to output
GPIO.setup([r1,r2,r3,r4], GPIO.OUT, initial=off)
# activate on sequence
if GPIO.input(r1) == on:
print('Already ON')
else:
print ('Activate ON sequence in %d s' % r1delay)
time.sleep(r1delay)
GPIO.output(r1, on)
print ('#1 on - wait %d s' % r2delay)
time.sleep(r2delay)
GPIO.output(r2, on)
print ('#2 on - wait %d s' % r3delay)
time.sleep(r3delay)
GPIO.output(r3, on)
print ('#3 on - wait %d s' % r4delay)
time.sleep(r4delay)
GPIO.output(r4, on)
print ('#4 on')
print ('OFF: roff.py')
create python relay-off script:
# nano /home/osmc/roff.py
add to the script:
#!/usr/bin/python
import time
# custom variables
r1 = 35
r2 = 36
r3 = 37
r4 = 38
# delay in seconds
r1delay = 3
r2delay = 1
r3delay = 2
r4delay = 3
on = 0
off = 1
# hide warning
GPIO.setwarnings(0)
# pins setup
# set pin to output
GPIO.setup([r1,r2,r3,r4], GPIO.OUT)
# activate off sequence
if GPIO.input(r1) == off:
print('Already OFF')
else:
print ('Activate OFF sequence in %d s' % r1delay)
time.sleep(r1delay)
GPIO.output(r1, off)
print ('#1 off - wait %d s' % r2delay)
time.sleep(r2delay)
GPIO.output(r2, off)
print ('#2 off - wait %d s' % r3delay)
time.sleep(r3delay)
GPIO.output(r3, off)
print ('#3 off - wait %d s' % r4delay)
time.sleep(r4delay)
GPIO.output(r4, off)
print ('#4 off')
# clear settings
GPIO.cleanup()
relays on:
# /home/osmc/ron.py
relays off:
# /home/osmc/roff.py
GPIO - Remote Control + Command
Keymaps:
‘System.Exec’
- has some difficuties running commands and scripts.
‘RunScript’
- a workaround but it will not run python scripts directly
- scripts must be called from another python script
os.system(‘sudo scriptfile’)
- system commands run fine with
os.system(‘sudo command’)
create python system command script for lon.py:
$ sudo su
# nano /home/osmc/loncmd.py
add to the script:
#!/usr/bin/python
import os
os.system('sudo /home/osmc/lon.py')
create python system command script for loff.py:
# nano /home/osmc/loffcmd.py
add to the script:
#!/usr/bin/python
import os
os.system('sudo /home/osmc/loff.py')
edit keymaps file (keyboard - use keyboard.xml):
# cp /usr/share/kodi/system/keymaps/remote.xml /home/osmc/.kodi/userdata/keymaps/
# nano /home/osmc/.kodi/userdata/keymaps/remote.xml
add to the script:
<?xml version="1.0" encoding="UTF-8"?>
<keymap>
<global>
<remote>
<zero>RunScript(/home/osmc/loffcmd.py)</zero>
<one>RunScript(/home/osmc/loncmd.py)</one>
</remote>
</global>
</keymap>
Restart to load the keymaps:
Power > Exit
LED on:
press button
LED off:
press button
GPIO - Run Script Startup
create systemd service file:
$ sudo su
# nano /lib/systemd/system/bshutdown.service
add to the file:
[Unit]
Description = GPIO shutdown button
[Service]
Type = idle
ExecStart = /home/osmc/bshutdown.py
[Install]
WantedBy = multi-user.target
enable the service:
# systemctl enable bshutdown
start the service:
# systemctl start bshutdown
