I’d like to post this in the how to section, but as a new user i don’t appear to have the needed permission.
This is a guide about how to use a rotary encoder connected to the pi’s gpio pins as a volume control.
this makes use of the rotary-encoder overlay and driver along with a custom driver. It should be noted that this currently only works on the dev branch, with kernel 4.14.30-2 or higher.
firstly we configure the rotary-encoder overlay, in /boot/config.txt add the following line:
dtoverlay=rotary-encoder-overlay:relative_axis=1,linux_axis=9
then we install the headers required to build the driver:
sudo apt-get install rbp2-headers-$(uname -r)
(change to rbp1 if single core pi)
symlink the header files:
sudo ln -s /usr/src/rbp2-headers-$(uname -r) /lib/modules/$(uname -r/build
in a folder create the following
makefile:
obj-m += gpio_volume.o
all:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
install:
cp gpio_volume.ko /lib/modules/$(shell uname -r)/kernel/drivers/input/keyboard/
chown root:root /lib/modules/$(shell uname -r)/kernel/drivers/input/keyboard/gpio_volume.ko
depmod -a
gpio_volume.c:
#define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
#include <linux/slab.h>
#include <linux/module.h>
#include <linux/input.h>
#include <linux/init.h>
#include <linux/device.h>
MODULE_AUTHOR("James Kent");
MODULE_DESCRIPTION("gpio rotary encoder as volume control module");
MODULE_LICENSE("GPL");
static char *devicename = "rotary@4";
module_param(devicename, charp, 0);
MODULE_PARM_DESC(devicename, "name of rotary input device");
static int reltype = REL_MISC; // 0x09
module_param(reltype, int, 0);
MODULE_PARM_DESC(reltype, "type of relative event to listen for");
static int count_per_press = 10;
module_param(count_per_press, int, 0);
MODULE_PARM_DESC(count_per_press, "event count before a press is generated");
static struct input_dev *button_dev;
static void send_key(int key) {
input_report_key(button_dev, key, 1);
input_sync(button_dev);
input_report_key(button_dev, key, 0);
int count = 0;
static void rotary_event(struct input_handle *handle, unsigned int type, unsigned int code, int value) {
printk(KERN_DEBUG pr_fmt("Event. Dev: %s, Type: %d, Code: %d, Value: %d\n"), dev_name(&handle->dev->dev), type, code, value);
if (type == EV_REL) {
if (code == reltype) {
int i;
int inc = (value > 0) ? 1 : -1;
if ((inc > 0 && count < 0) || (inc < 0 && count > 0)) { // if change of direction reset count
count = 0;
for (i=0; i!=value; i+=inc) {
count += inc;
if (abs(count) >= count_per_press) {
send_key( (inc > 0) ? KEY_VOLUMEUP : KEY_VOLUMEDOWN);
count = 0;
static int rotary_connect(struct input_handler *handler, struct input_dev *dev, const struct input_device_id *id) {
struct input_handle *handle;
int error;
handle = kzalloc(sizeof(struct input_handle), GFP_KERNEL);
if (!handle)
return -ENOMEM;
handle->dev = dev;
handle->handler = handler;
handle->name = "gpio_volume";
error = input_register_handle(handle);
if (error)
goto err_free_handle;
error = input_open_device(handle);
if (error)
goto err_unregister_handle;
printk(KERN_DEBUG pr_fmt("Connected device: %s (%s at %s)\n"),
dev_name(&dev->dev),
dev->name ?: "unknown",
dev->phys ?: "unknown");
return 0;
err_unregister_handle:
input_unregister_handle(handle);
err_free_handle:
kfree(handle);
return error;
bool startsWith(const char *pre, const char *str) {
size_t lenpre = strlen(pre),
lenstr = strlen(str);
return lenstr < lenpre ? false : strncmp(pre, str, lenpre) == 0;
// keep record of match and remove record is disconnect
bool matched = false;
static bool rotary_match(struct input_handler *handler, struct input_dev *dev) {
if (matched)
return false;
matched = startsWith(devicename, dev->name);
return matched;
static void rotary_disconnect(struct input_handle *handle) {
printk(KERN_DEBUG pr_fmt("Disconnected device: %s\n"), dev_name(&handle->dev->dev));
input_close_device(handle);
kfree(handle);
matched = false;
static const struct input_device_id rotary_ids[] = {
{ .driver_info = 1 }, /* Matches all devices */
{ }, /* Terminating zero entry */
MODULE_DEVICE_TABLE(input, rotary_ids);
static struct input_handler rotary_handler = {
.event = rotary_event,
.match = rotary_match,
.connect = rotary_connect,
.disconnect = rotary_disconnect,
.name = "gpio_volume",
.id_table = rotary_ids,
static int __init button_init(void) {
int error;
int i;
button_dev = input_allocate_device();
if (!button_dev) {
printk(KERN_ERR "gpio_volume: Not enough memory\n");
error = -ENOMEM;
return error;
button_dev->name = "GPIO Rotary Encoder Volume";
button_dev->evbit[0] = BIT_MASK(EV_KEY);// | BIT_MASK(EV_REP);
set_bit(KEY_VOLUMEDOWN, button_dev->keybit);
set_bit(KEY_VOLUMEUP, button_dev->keybit);
for (i=KEY_ESC; i<=KEY_KPDOT; i++) { // add a load of extra keys
set_bit(i, button_dev->keybit);
error = input_register_device(button_dev);
if (error) {
printk(KERN_ERR "gpio_volume: Failed to register device\n");
goto err_free_dev;
return 0;
err_free_dev:
input_free_device(button_dev);
return error;
static int __init gpio_volume_init(void) {
int error = button_init();
if (count_per_press < 1) // sanitise input
count_per_press = 1;
if (error == 0) {
if (input_register_handler(&rotary_handler)==0) {
printk(KERN_INFO "gpio_volume loaded.\n");
return 0;
} else {
input_unregister_device(button_dev);
return error;
static void __exit gpio_volume_exit(void) {
input_unregister_handler(&rotary_handler);
module_init(gpio_volume_init);
module_exit(gpio_volume_exit);
then run:
make
sudo make install
to auto load the driver on boot edit /etc/modules to add the following on it’s own line (requires sudo):
gpio_volume
in order for this to work in kodi its currently required to edit one of the udev rules:
/etc/udev/rules.d/998-fix-input.rules:
# input
KERNEL=="event*", MODE="0660", GROUP="osmc"
KERNEL=="event*", DRIVERS=="gpio-keys", MODE="0660", GROUP="root" # unrelated, allows gpio-shutdown overlay to work
KERNEL=="event*", DRIVERS=="rotary-encoder", MODE="0660", GROUP="root"
KERNEL=="mouse*|mice", MODE="0660", GROUP="osmc"
KERNEL=="ts[0-9]*|uinput", MODE="0660", GROUP="osmc"
KERNEL=="js[0-9]*", MODE="0660", GROUP="osmc"
this changes ownership of devices with the gpio-keys or rotary-encoder devices to the root group preventing kodi grabbing them.
currently kodi treats anything with 20 or less keys as “not a keyboard”, so the gpio-keys driver doesn’t work correctly. by changing ownership to root the power key is handled by systemd allowing it to work. this is also why the above driver reports being able to generate a lot of keys other than the volume up or down keys, so that kodi will recognise it.
