the red led is on (constant static on) on the board, but the green led doesn’t light up, or doesn’t give read/write (access) feedback.
what is the solution for this?
Thank you
if i put this on config.txt
dtparam=act_led_activelow=on
the green led is constant on.
or with
dtparam=act_led_trigger=heartbeat
gives a continuous pulsating (heartbeat)
all i need is a feedback from the led if there is an activity
thanks
edit
during wget a 100mb file green led stays black
after issue command sync
it will light up until sync lasts
am i thinking here wrong, and the green led is not suppose to show that there is an access to the sd only when sync is issued?
thanks
