My pi has suddenly after 2 years of working perfectly suddenly started to report undervoltage.
I have 2.5Amps charger and cable and I have tried several without any success.
I have an external harddrive connected through a powered usb hub.
At first I thought it was the hub, but even when hub is disconnected entirely and nothing but the ethernet cable and HDMI cable attached my PI still report undervoltage.
I have tried to increase USB voltage to max, but to no avail.
I have tried resetting, reinstalling, swapping out my sd-card and everything short of buying a new PI.
IS THERE a way to check if the problem is the PI itself? Or is there any other possible solutions you can think of?
Any input is greatly appreciated.
