RPi2 Transmission crashing whole system
Hello.
I have small problem with my Pi. I’ve installed Transmission from Appstore, configure without any problem but Transmission is runing only with two torrents. When i try to add third, works for few moment and crash whole system. OSMC gui is not responding, i can’t login with ssh and do anything. After this i must restart Pi by disconect power plug. I save everything on external HDD 3,5, it have own power supply. I also have connected by USB wifi card wn821n. When i start Pi, on right corner i see lightning icon - some problems with power supply? But i don’t it’s can have influence on transmission.
Logs: https://paste.osmc.tv/mitucamogo
I also trying install qbittorrent deamon, but after instalation when i trying to start this program or see his status or changing settings via ssh. I see only this informatio Unexpected reply signature: got \"\", expected \"a{sv}\
What i should check frist?
What power supply are you using?
Thanks Tom.
mobile charger 5V 2A
Mobile chargers don’t make good PSU’s. Also, if it’s a pi3, 2.5a is min recommended.
Your power supply probably isn’t up to scratch. You can learn more on our Wiki here: Frequently Asked Questions - Raspberry Pi - OSMC
i should buy a T5989DV or maybe something stronger like this:
ok, first i will try change PSU. i will return with answer
