it happened again and got the same error “no space left on device”.
http://paste.osmc.io/bitezekopu
had to restart the media center again.
Not sure what it is going on…
thanks
thanks
Unless it’s referring to the MyCloud it makes no sense, Attn @sam_nazarko [code]
====================== Diskspace =================== qZy25Yas
Filesystem Size Used Avail Use% Mounted on
devtmpfs 362M 0 362M 0% /dev
tmpfs 367M 5.0M 362M 2% /run
/dev/mmcblk0p2 29G 2.7G 25G 10% /
tmpfs 367M 0 367M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
192.168.1.130:/nfs 1.9G 836M 989M 46% /home/osmc/mnt/WDMYCloud
/dev/mmcblk0p1 240M 21M 220M 9% /boot
/dev/sda1 466G 280G 186G 61% /media/MYBOOK
192.168.1.130:/nfs/Public 2.7T 2.3T 408G 85% /home/osmc/mnt/WDMYCloud/Public
tmpfs 74M 0 74M 0% /run/user/1000
---------------------- Diskspace END --------------- qZy25Yas
[/code]
Would need to see a full set of logs after a manual attempt at an upgrade. /proc/mounts would also be good.
@antani You need to enable debug then grab a set of logs
I enabled debug and grabbed some more logs after it froze again.
http://paste.osmc.io/xunihifete
Then I restarted mediacenter (still same error about no space left) and grabbed again logs, just in case.
http://paste.osmc.io/yalalewija
Why should WDMYCLOUD be the issue? there are 400+ GB free…
EDITED: grammar didn’t make sense ![]()
I have a similar issue. After booting everything is fine and I can spend an entire evening watching content. When I go back a following day (I keep my RPi turned on) then OSMC will hang within a minute. This happens both when just browsing through the menus or when playing back a movie.
I can SSH in just fine and can reboot from there. Logs don’t show anything interesting, but I will see if I can enable debug logging.
I’ve tried updating the rbp2-mediacenter-osmc.deb but this did not solve it.
my clairvoyant abilities arent that good so mind forking over some logs or it didnt happen
$5 you got a shit repo installed
There’s a good chance of that
I’ll try to remove any dodgy repo’s and see if that helps.
Just out of curiosity, what is the reason a bad repo causes a hang, though? Is that documented somewhere?
https://kodi.tv/warning-be-aware-what-additional-add-ons-you-install/
3rd party addons are infiltrating the system quite aggressively and “hangs” is one possible outcome.
Pretty much the link that fzinken gave you i got some practical examples aswell if your really interested beyond the Kodi warning.
i wouldn’t want an infected device on my network…
LOL. I provided my logs and disabled superrepo. Not sure what else I can try…
Haha, finally
Maybe running out of inodes…
Can you give output for this command :
df -i
You can also have a look at this link
For using S.M.A.R.T under ![]()
sudo apt-get install smartmontools
here df -i. I will try later tonight with SMART.
osmc@osmc:~$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
devtmpfs 92635 353 92282 1% /dev
tmpfs 93883 417 93466 1% /run
/dev/mmcblk0p2 1941504 38990 1902514 3% /
tmpfs 93883 1 93882 1% /dev/shm
tmpfs 93883 3 93880 1% /run/lock
tmpfs 93883 10 93873 1% /sys/fs/cgroup
192.168.1.130:/nfs 125184 38773 86411 31% /home/osmc/mnt/WDMYCloud
/dev/mmcblk0p1 0 0 0 - /boot
/dev/sda1 196414884 168452 196246432 1% /media/MYBOOK
192.168.1.130:/nfs/Public 182853632 102125 182751507 1% /home/osmc/mnt/WDMYCloud/Public
tmpfs 93883 4 93879 1% /run/user/1000
Everything looks fine with df -i
I’ve removed unusual repositories but the problem still persists. Debug logging is available here: http://paste.osmc.io/exehahuqey.vhdl
This happens after OSMC has been idle for a couple of hours. It either hangs during browsing of the video list or immediately after playback of a video has started. SSH is still working though, so I was able to grab the log.
I’m running the latest available version of OSMC along with the updated rbp2-mediacenter-osmc package mentioned in this thread.
Revert overclock back to normal profile and test again.
It’s not overclocked.
