I’m using latest version on RPI2. Medias are stored on a NFS drive.
Every once in a while (once every 2 days probably) while I scroll through items (movies, TV shows, …), the interface freezes. No further input is received from the Samsung TV remove (CEC), kodi app on the iphone, …
I need to ssh and restart the medicenter then everything works normally.
Here the logs right after the system froze and before restarting the media center http://paste.osmc.io/efogujeqar
Only once the freeze occurred while playing a video. Also, every time I restart mediacenter through ssh (sudo systemctl restart mediacenter) I receive the following error on console.
Error: No space left on device
As you can see from the logs, there is plenty of space available.
Sorry did not check his logs, too lazy
I deleted my post.
Maybe a problem with advancedsettings.xml, keyboard.xml and remote.xml.
Just a question @antani, why are you mounting external drive and nas in /home/osmc/mnt ?
Sorry if it’s a foolish question.
Thanks for the reply.
I know it should be working either way but why not keeping it automount in /media ? Because it is more practical/convenient ? Better for permission management or something like that ?
Thank you everyone.
About mount: I have some scripts and programs I use on the OSMC and thus need a mount available from the CLI.
About super-repo: I did not remove anything from logs. I believe Super-Repo is still active as I have tons of addons I can select from. Should I remove it?
About omxplayer: did not try. Do you guys want me to try with super-repo first or omxplayer?
Just light reading over 3rd party repoes not saying that this happend too you just so your aware of what your doing to your system free content isn’t always free.
thanks for the links on unofficial repos. How can I remove the entire super-repo?
I activate the omxplayer and tried to use osmc a bit.
It occurred within 2 minutes again.
Here the new logs. http://paste.osmc.io/fukafeguzu
I enabled the omxplayer first and “crashed” (as described above) right within a few minutes.
see logs above.
I then disabled super-repo (thanks for the instructions!).
I will get back to this thread to see if i encounter the same issue.
so I installed.
For some reason during the process it gave me again the “no space left” error, like noted above, even though there is plenty of space.
used it a bit and did not encounter issues after the reboot.
Error is
“Error: no space left on device”
as noted in the 1st post.
Such error is given on console on standard output. I have seen it when i do the mediacenter restart to fix the issue, and it showed when i installed the .deb sam provided, or when i rebooted.
