RcBRrsRs : APT term.log
B8sj7DO8 : APT history.log
ZZz2wrJ1 : APT sources.list
fFsk1x85 : APT apt.conf.d
vSKj25Lq : APT preferences.d
====================== APT term.log =================== RcBRrsRs
Log started: 2016-12-07 19:19:40
Selecting previously unselected package fonts-dejavu-core.
Preparing to unpack …/fonts-dejavu-core_2.34-1_all.deb …
Unpacking fonts-dejavu-core (2.34-1) …
Selecting previously unselected package fontconfig-config.
Preparing to unpack …/fontconfig-config_2.11.0-6.3+deb8u1_all.deb …
Unpacking fontconfig-config (2.11.0-6.3+deb8u1) …
Selecting previously unselected package libfontconfig1:armhf.
Preparing to unpack …/libfontconfig1_2.11.0-6.3+deb8u1_armhf.deb …
Unpacking libfontconfig1:armhf (2.11.0-6.3+deb8u1) …
Selecting previously unselected package fontconfig.
Preparing to unpack …/fontconfig_2.11.0-6.3+deb8u1_armhf.deb …
Unpacking fontconfig (2.11.0-6.3+deb8u1) …
Selecting previously unselected package libxau6:armhf.
Preparing to unpack …/libxau6_1%3a1.0.8-1_armhf.deb …
Unpacking libxau6:armhf (1:1.0.8-1) …
Selecting previously unselected package x11-common.
Preparing to unpack …/x11-common_1%3a7.7+7_all.deb …
Unpacking x11-common (1:7.7+7) …
Selecting previously unselected package libice6:armhf.
Preparing to unpack …/libice6_2%3a1.0.9-1+b1_armhf.deb …
Unpacking libice6:armhf (2:1.0.9-1+b1) …
Selecting previously unselected package libsm6:armhf.
Preparing to unpack …/libsm6_2%3a1.2.2-1+b1_armhf.deb …
Unpacking libsm6:armhf (2:1.2.2-1+b1) …
Selecting previously unselected package libxdmcp6:armhf.
Preparing to unpack …/libxdmcp6_1%3a1.1.1-1+b1_armhf.deb …
Unpacking libxdmcp6:armhf (1:1.1.1-1+b1) …
Selecting previously unselected package libxcb1:armhf.
Preparing to unpack …/libxcb1_1.10-3+b1_armhf.deb …
Unpacking libxcb1:armhf (1.10-3+b1) …
Selecting previously unselected package libx11-data.
Preparing to unpack …/libx11-data_2%3a1.6.2-3_all.deb …
Unpacking libx11-data (2:1.6.2-3) …
Selecting previously unselected package libx11-6:armhf.
Preparing to unpack …/libx11-6_2%3a1.6.2-3_armhf.deb …
Unpacking libx11-6:armhf (2:1.6.2-3) …
Selecting previously unselected package libxt6:armhf.
Preparing to unpack …/libxt6_1%3a1.1.4-1+b1_armhf.deb …
Unpacking libxt6:armhf (1:1.1.4-1+b1) …
Selecting previously unselected package libaudio2:armhf.
Preparing to unpack …/libaudio2_1.9.4-3_armhf.deb …
Unpacking libaudio2:armhf (1.9.4-3) …
Selecting previously unselected package libmng1:armhf.
Preparing to unpack …/libmng1_1.0.10+dfsg-3.1+b3_armhf.deb …
Unpacking libmng1:armhf (1.0.10+dfsg-3.1+b3) …
Selecting previously unselected package qtcore4-l10n.
Preparing to unpack …/qtcore4-l10n_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_all.deb …
Unpacking qtcore4-l10n (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libqtcore4:armhf.
Preparing to unpack …/libqtcore4_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_armhf.deb …
Unpacking libqtcore4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libqt4-xml:armhf.
Preparing to unpack …/libqt4-xml_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_armhf.deb …
Unpacking libqt4-xml:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libqtdbus4:armhf.
Preparing to unpack …/libqtdbus4_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_armhf.deb …
Unpacking libqtdbus4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libqt4-network:armhf.
Preparing to unpack …/libqt4-network_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_armhf.deb …
Unpacking libqt4-network:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libxext6:armhf.
Preparing to unpack …/libxext6_2%3a1.3.3-1_armhf.deb …
Unpacking libxext6:armhf (2:1.3.3-1) …
Selecting previously unselected package libxrender1:armhf.
Preparing to unpack …/libxrender1_1%3a0.9.8-1+b1_armhf.deb …
Unpacking libxrender1:armhf (1:0.9.8-1+b1) …
Selecting previously unselected package libqtgui4:armhf.
Preparing to unpack …/libqtgui4_4%3a4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1_armhf.deb …
Unpacking libqtgui4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Selecting previously unselected package libusb-1.0-0:armhf.
Preparing to unpack …/libusb-1.0-0_2%3a1.0.19-1_armhf.deb …
Unpacking libusb-1.0-0:armhf (2:1.0.19-1) …
Processing triggers for systemd (215-17+deb8u5) …
Setting up fonts-dejavu-core (2.34-1) …
Setting up fontconfig-config (2.11.0-6.3+deb8u1) …
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (Can’t locate Term/ReadLine.pm in @INC (you may need to install the Term::ReadLine module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at /usr/share/perl5/Debconf/FrontEnd/Readline.pm line 7.)
debconf: falling back to frontend: Teletype
Setting up libfontconfig1:armhf (2.11.0-6.3+deb8u1) …
Setting up fontconfig (2.11.0-6.3+deb8u1) …
Regenerating fonts cache… done.
Setting up libxau6:armhf (1:1.0.8-1) …
Setting up x11-common (1:7.7+7) …
/var/lib/dpkg/info/x11-common.postinst: 697: /var/lib/dpkg/info/x11-common.postinst: update-rc.d: not found
dpkg: error processing package x11-common (–configure):
subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of libice6:armhf:
libice6:armhf depends on x11-common; however:
Package x11-common is not configured yet.
dpkg: error processing package libice6:armhf (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libsm6:armhf:
libsm6:armhf depends on libice6 (>= 1:1.0.0); however:
Package libice6:armhf is not configured yet.
dpkg: error processing package libsm6:armhf (–configure):
Setting up libxdmcp6:armhf (1:1.1.1-1+b1) …
Setting up libxcb1:armhf (1.10-3+b1) …
Setting up libx11-data (2:1.6.2-3) …
Setting up libx11-6:armhf (2:1.6.2-3) …
dpkg: dependency problems prevent configuration of libxt6:armhf:
libxt6:armhf depends on libice6 (>= 1:1.0.0); however:
libxt6:armhf depends on libsm6; however:
Package libsm6:armhf is not configured yet.
dpkg: error processing package libxt6:armhf (–configure):
dpkg: dependency problems prevent configuration of libaudio2:armhf:
libaudio2:armhf depends on libxt6; however:
Package libxt6:armhf is not configured yet.
dpkg: error processing package libaudio2:armhf (–configure):
Setting up libmng1:armhf (1.0.10+dfsg-3.1+b3) …
Setting up qtcore4-l10n (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up libqtcore4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up libqt4-xml:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up libqtdbus4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up libqt4-network:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up libxext6:armhf (2:1.3.3-1) …
Setting up libxrender1:armhf (1:0.9.8-1+b1) …
dpkg: dependency problems prevent configuration of libqtgui4:armhf:
libqtgui4:armhf depends on libaudio2; however:
Package libaudio2:armhf is not configured yet.
libqtgui4:armhf depends on libice6 (>= 1:1.0.0); however:
libqtgui4:armhf depends on libsm6; however:
dpkg: error processing package libqtgui4:armhf (–configure):
Setting up libusb-1.0-0:armhf (2:1.0.19-1) …
Processing triggers for libc-bin (2.19-18+deb8u6) …
x11-common
libice6:armhf
libsm6:armhf
libxt6:armhf
libaudio2:armhf
libqtgui4:armhf
Log ended: 2016-12-07 19:20:33
Log started: 2016-12-10 18:09:18
Selecting previously unselected package usbutils.
Preparing to unpack …/usbutils_1%3a007-2_armhf.deb …
Unpacking usbutils (1:007-2) …
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up libice6:armhf (2:1.0.9-1+b1) …
Setting up libsm6:armhf (2:1.2.2-1+b1) …
Setting up libxt6:armhf (1:1.1.4-1+b1) …
Setting up libaudio2:armhf (1.9.4-3) …
Setting up libqtgui4:armhf (4:4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1) …
Setting up usbutils (1:007-2) …
Log ended: 2016-12-10 18:09:24
Log started: 2016-12-11 08:09:05
Selecting previously unselected package firmware-realtek.
Preparing to unpack …/firmware-realtek_0.43_all.deb …
Unpacking firmware-realtek (0.43) …
dpkg: error processing archive /var/cache/apt/archives/firmware-realtek_0.43_all.deb (–unpack):
trying to overwrite ‘/lib/firmware/RTL8192SU/rtl8192sfw.bin’, which is also in package wireless-firmware-osmc 1.1.2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Log ended: 2016-12-11 08:09:06
Log started: 2016-12-11 08:43:52
Selecting previously unselected package dnsutils.
Preparing to unpack …/dnsutils_1%3a9.9.5.dfsg-9+deb8u8_armhf.deb …
Unpacking dnsutils (1:9.9.5.dfsg-9+deb8u8) …
Selecting previously unselected package shishi-common.
Preparing to unpack …/shishi-common_1.0.2-5_all.deb …
Unpacking shishi-common (1.0.2-5) …
Selecting previously unselected package libshishi0.
Preparing to unpack …/libshishi0_1.0.2-5_armhf.deb …
Unpacking libshishi0 (1.0.2-5) …
Selecting previously unselected package inetutils-telnet.
Preparing to unpack …/inetutils-telnet_2%3a1.9.2.39.3a460-3_armhf.deb …
Unpacking inetutils-telnet (2:1.9.2.39.3a460-3) …
Setting up dnsutils (1:9.9.5.dfsg-9+deb8u8) …
Setting up shishi-common (1.0.2-5) …
Setting up libshishi0 (1.0.2-5) …
Setting up inetutils-telnet (2:1.9.2.39.3a460-3) …
update-alternatives: using /usr/bin/inetutils-telnet to provide /usr/bin/telnet (telnet) in auto mode
Log ended: 2016-12-11 08:43:59
Log started: 2016-12-11 08:47:04
Preparing to unpack …/tar_1.27.1-2+deb8u1_armhf.deb …
Unpacking tar (1.27.1-2+deb8u1) over (1.27.1-2+b1) …
Processing triggers for mime-support (3.58) …
Setting up tar (1.27.1-2+deb8u1) …
update-alternatives: warning: forcing reinstallation of alternative /usr/sbin/rmt-tar because link group rmt is broken
Preparing to unpack …/tzdata_2016j-0+deb8u1_all.deb …
Unpacking tzdata (2016j-0+deb8u1) over (2016f-0+deb8u1) …
Setting up tzdata (2016j-0+deb8u1) …
Current default time zone: ‘Europe/Madrid’
Local time is now: Sun Dec 11 08:47:19 CET 2016.
Universal Time is now: Sun Dec 11 07:47:19 UTC 2016.
Run ‘dpkg-reconfigure tzdata’ if you wish to change it.
Log ended: 2016-12-11 08:47:20
---------------------- APT term.log END --------------- RcBRrsRs
====================== APT history.log =================== B8sj7DO8
Start-Date: 2016-12-07 19:19:40
Commandline: /usr/bin/apt-get-real -qq --yes install libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 ca-certificates
Install: libfontconfig1:armhf (2.11.0-6.3+deb8u1, automatic), libqtcore4:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1), libsm6:armhf (1.2.2-1+b1, automatic), qtcore4-l10n:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1, automatic), libmng1:armhf (1.0.10+dfsg-3.1+b3, automatic), libxrender1:armhf (0.9.8-1+b1, automatic), libx11-data:armhf (1.6.2-3, automatic), libxt6:armhf (1.1.4-1+b1, automatic), fontconfig:armhf (2.11.0-6.3+deb8u1, automatic), libxdmcp6:armhf (1.1.1-1+b1, automatic), libqtdbus4:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1, automatic), libx11-6:armhf (1.6.2-3, automatic), x11-common:armhf (7.7+7, automatic), fontconfig-config:armhf (2.11.0-6.3+deb8u1, automatic), libqt4-network:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1), libxext6:armhf (1.3.3-1, automatic), libxau6:armhf (1.0.8-1, automatic), libusb-1.0-0:armhf (1.0.19-1), libice6:armhf (1.0.9-1+b1, automatic), libqtgui4:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1), libaudio2:armhf (1.9.4-3, automatic), libqt4-xml:armhf (4.8.6+git64-g5dc8b2b+dfsg-3+deb8u1, automatic), libxcb1:armhf (1.10-3+b1, automatic), fonts-dejavu-core:armhf (2.34-1, automatic)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2016-12-07 19:20:33
Start-Date: 2016-12-10 18:09:18
Commandline: /usr/bin/apt-get-real install usbutils
Install: usbutils:armhf (007-2)
End-Date: 2016-12-10 18:09:24
Start-Date: 2016-12-11 08:09:05
Commandline: /usr/bin/apt-get-real install firmware-realtek
Install: firmware-realtek:armhf (0.43)
End-Date: 2016-12-11 08:09:06
Start-Date: 2016-12-11 08:43:52
Commandline: /usr/bin/apt-get-real install bind9-host dnsutils inetutils-telnet
Install: shishi-common:armhf (1.0.2-5, automatic), inetutils-telnet:armhf (1.9.2.39.3a460-3), dnsutils:armhf (9.9.5.dfsg-9+deb8u8), libshishi0:armhf (1.0.2-5, automatic)
End-Date: 2016-12-11 08:43:59
Start-Date: 2016-12-11 08:47:04
Commandline: /usr/bin/apt-get-real dist-upgrade
Upgrade: tzdata:armhf (2016f-0+deb8u1, 2016j-0+deb8u1), tar:armhf (1.27.1-2+b1, 1.27.1-2+deb8u1)
End-Date: 2016-12-11 08:47:20
---------------------- APT history.log END --------------- B8sj7DO8
====================== APT sources.list =================== ZZz2wrJ1
deb Index of /debian jessie main contrib non-free
deb Index of /debian jessie-updates main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://apt.osmc.tv jessie main
---------------------- APT sources.list END --------------- ZZz2wrJ1
====================== APT apt.conf.d =================== fFsk1x85
total 36
drwxr-xr-x 2 root root 4096 Jan 1 1970 .
drwxr-xr-x 6 root root 4096 Jan 1 1970 …
-rw-r–r-- 1 root root 26 Nov 22 01:10 00-osmc-fancy-progressbar
-rw-r–r-- 1 root root 62 Nov 22 01:10 00-osmc-no-prompt-conffiles
-rw-r–r-- 1 root root 56 Nov 22 01:10 00-osmc-no-recommends-or-suggests
-rw-r–r-- 1 root root 38 Nov 22 01:10 00-osmc-user-agent
-rw-r–r-- 1 root root 643 Mar 13 2016 01autoremove
-rw-r–r-- 1 root root 981 Nov 28 01:38 01autoremove-kernels
-rw-r–r-- 1 root root 182 Mar 19 2015 70debconf
---------------------- APT apt.conf.d END --------------- fFsk1x85
====================== APT preferences.d =================== vSKj25Lq
total 12
-rw-r–r-- 1 root root 56 Nov 22 01:10 kernel-common
---------------------- APT preferences.d END --------------- vSKj25Lq
