After purchasing a case for the RPi3 I shutdown the OSMC.
After placing the RPi3 in the case restarted, the RPi did not give any display, after an reboot I have a display.
But I find after running the dsmeg in the terminal, messages of a corrupted MicroSD card.
- Who can I fix this?
On for hand thanks for your help!
Robert
dsmesg output:
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.3-3-osmc (root@rpi2) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Mar 1 15:51:08 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bcd900, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefaa000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa02082 bcm2709.serial=0xc80e74ae smsc95xx.macaddr=B8:27:EB:0E:74:AE bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741080K/770048K available (7997K kernel code, 437K rwdata, 1864K rodata, 1792K init, 764K bss, 20776K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x809a9764 (9862 kB)
.init : 0x809aa000 - 0x80b6a000 (1792 kB)
.data : 0x80b6a000 - 0x80bd75f4 ( 438 kB)
.bss : 0x80bda000 - 0x80c992ac ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000260] Console: colour dummy device 80x30
[ 0.000446] console [tty0] enabled
[ 0.000468] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000488] pid_max: default: 32768 minimum: 301
[ 0.000778] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000793] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001741] Disabling cpuset control group subsystem
[ 0.001774] Initializing cgroup subsys io
[ 0.001801] Initializing cgroup subsys memory
[ 0.001837] Initializing cgroup subsys devices
[ 0.001854] Initializing cgroup subsys freezer
[ 0.001874] Initializing cgroup subsys net_cls
[ 0.001919] CPU: Testing write buffer coherency: ok
[ 0.001976] ftrace: allocating 19380 entries in 57 pages
[ 0.047979] CPU0: update cpu_capacity 1024
[ 0.048010] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048023] [bcm2709_smp_prepare_cpus] enter
[ 0.048162] Setting up static identity map for 0x8240 - 0x8298
[ 0.127540] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.127730] [bcm2709_secondary_init] enter cpu:1
[ 0.127771] CPU1: update cpu_capacity 1024
[ 0.127777] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.157550] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.157689] [bcm2709_secondary_init] enter cpu:2
[ 0.157711] CPU2: update cpu_capacity 1024
[ 0.157717] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.187601] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.187731] [bcm2709_secondary_init] enter cpu:3
[ 0.187752] CPU3: update cpu_capacity 1024
[ 0.187758] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.187823] Brought up 4 CPUs
[ 0.187846] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.187855] CPU: All CPU(s) started in HYP mode.
[ 0.187862] CPU: Virtualization extensions available.
[ 0.188459] devtmpfs: initialized
[ 0.197642] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.197996] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.198746] pinctrl core: initialized pinctrl subsystem
[ 0.199300] NET: Registered protocol family 16
[ 0.204084] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.227656] cpuidle: using governor ladder
[ 0.257679] cpuidle: using governor menu
[ 0.263529] bcm2709: Mini UART enabled
[ 0.263569] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.263581] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.263716] Serial: AMBA PL011 UART driver
[ 0.263850] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.264014] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.328788] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.330309] SCSI subsystem initialized
[ 0.330488] usbcore: registered new interface driver usbfs
[ 0.330577] usbcore: registered new interface driver hub
[ 0.330677] usbcore: registered new device driver usb
[ 0.337801] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-25 18:56
[ 0.364626] clocksource: Switched to clocksource arch_sys_counter
[ 0.409785] FS-Cache: Loaded
[ 0.410076] CacheFiles: Loaded
[ 0.422114] NET: Registered protocol family 2
[ 0.422950] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.423064] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.423252] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.423346] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.423393] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.423634] NET: Registered protocol family 1
[ 0.423967] RPC: Registered named UNIX socket transport module.
[ 0.423978] RPC: Registered udp transport module.
[ 0.423986] RPC: Registered tcp transport module.
[ 0.423995] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.519131] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.520917] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.521008] audit: initializing netlink subsys (disabled)
[ 0.521058] audit: type=2000 audit(0.489:1): initialized
[ 0.533987] VFS: Disk quotas dquot_6.6.0
[ 0.534299] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.536622] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.537497] NFS: Registering the id_resolver key type
[ 0.537550] Key type id_resolver registered
[ 0.537560] Key type id_legacy registered
[ 0.539950] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.540073] io scheduler noop registered
[ 0.540542] io scheduler bfq registered (default)
[ 0.540551] BFQ I/O-scheduler version: v7r7
[ 0.543008] BCM2708FB: allocated DMA memory ee800000
[ 0.543035] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.573801] Console: switching to colour frame buffer device 240x67
[ 1.595361] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.595472] vc-cma: Videocore CMA driver
[ 1.595482] vc-cma: vc_cma_base = 0x00000000
[ 1.595492] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.595501] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.595721] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.610743] brd: module loaded
[ 1.619409] loop: module loaded
[ 1.620284] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.621785] Loading iSCSI transport class v2.0-870.
[ 1.622543] usbcore: registered new interface driver smsc95xx
[ 1.622586] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.822843] Core Release: 2.80a
[ 1.822858] Setting default values for core params
[ 1.822878] Finished setting default values for core params
[ 2.023235] Using Buffer DMA mode
[ 2.023246] Periodic Transfer Interrupt Enhancement - disabled
[ 2.023254] Multiprocessor Interrupt Enhancement - disabled
[ 2.023264] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.023275] Dedicated Tx FIFOs mode
[ 2.023590] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 2.023619] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.023639] dwc_otg: Microframe scheduler enabled
[ 2.023690] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8057a3e8
[ 2.023706] WARN::hcd_init_fiq:414: FIQ ASM at 0x8057a758 length 36
[ 2.023721] WARN::hcd_init_fiq:439: MPHI regs_base at 0xafc7e000
[ 2.023785] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.023824] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.023861] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.023911] Init: Port Power? op_state=1
[ 2.023919] Init: Power Port (0)
[ 2.024138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.024154] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.024167] usb usb1: Product: DWC OTG Controller
[ 2.024179] usb usb1: Manufacturer: Linux 4.4.3-3-osmc dwc_otg_hcd
[ 2.024192] usb usb1: SerialNumber: 3f980000.usb
[ 2.025047] hub 1-0:1.0: USB hub found
[ 2.025098] hub 1-0:1.0: 1 port detected
[ 2.025704] dwc_otg: FIQ enabled
[ 2.025715] dwc_otg: NAK holdoff enabled
[ 2.025723] dwc_otg: FIQ split-transaction FSM enabled
[ 2.025756] Module dwc_common_port init
[ 2.026009] usbcore: registered new interface driver usb-storage
[ 2.026279] mousedev: PS/2 mouse device common for all mice
[ 2.026727] usbcore: registered new interface driver usbtouchscreen
[ 2.026997] bcm2835-cpufreq: min=600000 max=1200000
[ 2.029088] sdhci: Secure Digital Host Controller Interface driver
[ 2.029094] sdhci: Copyright© Pierre Ossman
[ 2.029261] sdhost: log_buf @ ae813000 (ee813000)
[ 2.104646] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.126792] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.126800] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.161460] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.163294] mmc0: new high speed SDHC card at address b368
[ 2.163585] mmcblk0: mmc0:b368 USD 14.9 GiB
[ 2.164525] mmcblk0: p1 p2
[ 2.164704] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.164916] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.164974] hidraw: raw HID events driver © Jiri Kosina
[ 2.165065] usbcore: registered new interface driver usbhid
[ 2.165069] usbhid: USB HID core driver
[ 2.165336] Initializing XFRM netlink socket
[ 2.165354] NET: Registered protocol family 17
[ 2.165430] Key type dns_resolver registered
[ 2.165514] Registering SWP/SWPB emulation handler
[ 2.165936] registered taskstats version 1
[ 2.166040] vc-sm: Videocore shared memory driver
[ 2.166048] [vc_sm_connected_init]: start
[ 2.166314] [vc_sm_connected_init]: end - returning 0
[ 2.168728] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 2.170762] Freeing unused kernel memory: 1792K (809aa000 - 80b6a000)
[ 2.187198] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.188695] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.190192] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.192878] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.224747] Indeed it is in host mode hprt0 = 00021501
[ 2.298625] mmc1: new high speed SDIO card at address 0001
[ 2.404654] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.404747] Indeed it is in host mode hprt0 = 00001101
[ 2.604815] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.604828] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.605356] hub 1-1:1.0: USB hub found
[ 2.605417] hub 1-1:1.0: 5 ports detected
[ 2.884653] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.984831] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.984844] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.987396] smsc95xx v1.0.4
[ 3.046662] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:0e:74:ae
[ 29.859689] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 29.865282] fsck: E2fsck run: /bin/e2fsck -f -y -C 0 /dev/mmcblk0p2
[ 29.865376] fsck: e2fsck 1.42.13 (17-May-2015)
[ 29.865501] fsck: Filesystem UUID: 81cfaa57-3e50-44db-b14b-995bb325dca8
[ 29.865609] fsck: Pass 1: Checking inodes, blocks, and sizes
[ 29.865706] fsck: Pass 2: Checking directory structure
[ 29.865807] fsck: Pass 3: Checking directory connectivity
[ 29.865898] fsck: Pass 4: Checking reference counts
[ 29.865973] fsck: Unattached inode 262453
[ 29.866057] fsck: Connect to /lost+found? yes
[ 29.866094] fsck:
[ 29.866218] fsck: Inode 262453 ref count is 2, should be 1. Fix? yes
[ 29.866255] fsck:
[ 29.866330] fsck: Unattached inode 654103
[ 29.866413] fsck: Connect to /lost+found? yes
[ 29.866450] fsck:
[ 29.866573] fsck: Inode 654103 ref count is 2, should be 1. Fix? yes
[ 29.866610] fsck:
[ 29.866715] fsck: Pass 5: Checking group summary information
[ 29.866811] fsck: Block bitmap differences: -1692094
[ 29.866864] fsck: Fix? yes
[ 29.866902] fsck:
[ 29.867022] fsck: Free blocks count wrong (3533919, counted=3550136).
[ 29.867074] fsck: Fix? yes
[ 29.867111] fsck:
[ 29.867148] fsck:
[ 29.867272] fsck: /dev/mmcblk0p2: ***** FILE SYSTEM WAS MODIFIED *****
[ 29.867438] fsck: /dev/mmcblk0p2: 29602/964768 files (0.1% non-contiguous), 304712/3854848 blocks
[ 30.959793] random: systemd urandom read with 114 bits of entropy available
[ 31.002800] NET: Registered protocol family 10
[ 31.293579] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 31.293711] systemd[1]: Found ordering cycle on basic.target/start
[ 31.293721] systemd[1]: Found dependency on sysinit.target/start
[ 31.293732] systemd[1]: Found dependency on kbd.service/start
[ 31.293742] systemd[1]: Found dependency on remote-fs.target/start
[ 31.293752] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 31.293761] systemd[1]: Found dependency on connman.service/start
[ 31.293770] systemd[1]: Found dependency on dbus.service/start
[ 31.293779] systemd[1]: Found dependency on basic.target/start
[ 31.293788] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 31.293799] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 31.293931] systemd[1]: Found ordering cycle on basic.target/start
[ 31.293942] systemd[1]: Found dependency on sysinit.target/start
[ 31.293953] systemd[1]: Found dependency on rpcbind.service/start
[ 31.293964] systemd[1]: Found dependency on network-online.target/start
[ 31.293973] systemd[1]: Found dependency on network.target/start
[ 31.293981] systemd[1]: Found dependency on connman.service/start
[ 31.293990] systemd[1]: Found dependency on dbus.service/start
[ 31.293999] systemd[1]: Found dependency on basic.target/start
[ 31.294008] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 31.294019] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 31.403143] fuse init (API version 7.23)
[ 32.122767] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 32.225226] systemd-udevd[193]: starting version 215
[ 32.403478] lirc_dev: IR Remote Control driver registered, major 245
[ 32.407528] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 32.473897] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 32.475131] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 32.703640] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 32.703989] usbcore: registered new interface driver brcmfmac
[ 32.782269] random: nonblocking pool is initialized
[ 32.845542] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[ 32.862165] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 32.913991] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 33.364652] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 33.364849] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 33.364856] lirc_rpi: driver registered!
[ 35.255944] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 35.256244] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 35.387775] systemd-journald[171]: Received request to flush runtime journal from PID 1
[ 35.554125] input: lircd as /devices/virtual/input/input0
[ 35.737796] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 35.737811] brcmfmac: brcmf_add_if: ignore IF event
[ 35.745673] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 36.658301] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 36.661854] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE1
[ 36.687807] 8021q: 802.1Q VLAN Support v1.8
[ 36.698988] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 41.059887] Console: switching to colour dummy device 80x30
