My Pi3 has been freezing up frequently, normally when I’m not using it. I am not able to ssh it and only a power reset is starting it up.
I have an external powered HD and canakit power supply on kit. Also running couchpotato, sickrage and transmission besides OSMC.
Recently I have format and reinstall my system hoping to solve the problem, but it didn’t work.
You have not enabled debug logging prior to the issue manifesting itself and your acquisition of logs. I see nothing in these logs that points to the problem but, without debug enabled, they are less than verbose. Enabling debug logging and capturing the issue again may provide some insight.
I believe I do have enabled the logging, not sure why it didn’t upload.
I have a kodi.old.log on /home/osmc/.kodi/temp folder. Can I upload the file here?
@sam_nazarko tks for the reply. I’ll change the PSU but I haven’t seen any sign it’s not delivering enough power.
But your post reminded me of a hint… Usually when it freezes I see one of these icons on the top right hand corner of the screen:
even though having heatsinks installed. The pi3 case is usually hot.
My guess is that it’s freezing during some scheduled processing or scanning, something that consumes CPU but I can’t seem to find what it is…
