Hello World!
I have a problem with my OSMC. Everytime I try to clean the library, OSMC is freezing. Is it possible to cleanup the lib via term (or to fix the problem)?
Thanks for your help!
Frank
Hello World!
Frank
Hey @ooZee,
attached please find the LOG-File:
18:47:30.556 T:1958748160 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:47:30.556 T:1958748160 NOTICE: -----------------------------------------------------------------------
18:47:30.556 T:1958748160 NOTICE: Starting Kodi (17.5). Platform: Linux ARM (Thumb) 32-bit
18:47:30.556 T:1958748160 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
18:47:30.556 T:1958748160 NOTICE: Kodi compiled Oct 29 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
18:47:30.556 T:1958748160 NOTICE: Running on Open Source Media Center 2017.10-1, kernel: Linux ARM 32-bit version 4.9.29-10-osmc
18:47:30.556 T:1958748160 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
18:47:30.556 T:1958748160 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
18:47:30.556 T:1958748160 NOTICE: ARM Features: Neon disabled
18:47:30.556 T:1958748160 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:47:30.556 T:1958748160 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
18:47:30.556 T:1958748160 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
18:47:30.556 T:1958748160 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
18:47:30.556 T:1958748160 NOTICE: special://envhome/ is mapped to: /home/osmc
18:47:30.556 T:1958748160 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
18:47:30.556 T:1958748160 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
18:47:30.556 T:1958748160 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
18:47:30.556 T:1958748160 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
18:47:30.556 T:1958748160 NOTICE: Local hostname: osmc-wz
18:47:30.557 T:1958748160 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
18:47:30.557 T:1958748160 NOTICE: -----------------------------------------------------------------------
18:47:30.748 T:1958748160 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
18:47:30.797 T:1958748160 NOTICE: load settings...
18:47:30.939 T:1958748160 NOTICE: Found 2 Lists of Devices
18:47:30.939 T:1958748160 NOTICE: Enumerated PI devices:
18:47:30.939 T:1958748160 NOTICE: Device 1
18:47:30.940 T:1958748160 NOTICE: m_deviceName : HDMI
18:47:30.940 T:1958748160 NOTICE: m_displayName : HDMI
18:47:30.940 T:1958748160 NOTICE: m_displayNameExtra:
18:47:30.940 T:1958748160 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:47:30.940 T:1958748160 NOTICE: m_channels : FL,FR
18:47:30.940 T:1958748160 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
18:47:30.940 T:1958748160 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
18:47:30.940 T:1958748160 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
18:47:30.940 T:1958748160 NOTICE: Device 2
18:47:30.940 T:1958748160 NOTICE: m_deviceName : Analogue
18:47:30.940 T:1958748160 NOTICE: m_displayName : Analogue
18:47:30.940 T:1958748160 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:47:30.940 T:1958748160 NOTICE: m_sampleRates : 48000
18:47:30.940 T:1958748160 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
18:47:30.940 T:1958748160 NOTICE: m_streamTypes : No passthrough capabilities
18:47:30.940 T:1958748160 NOTICE: Device 3
18:47:30.940 T:1958748160 NOTICE: m_deviceName : Both
18:47:30.940 T:1958748160 NOTICE: m_displayName : HDMI and Analogue
18:47:30.940 T:1958748160 NOTICE: Enumerated ALSA devices:
18:47:30.940 T:1958748160 NOTICE: Device 1
18:47:30.940 T:1958748160 NOTICE: m_deviceName : @
18:47:30.940 T:1958748160 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
18:47:30.940 T:1958748160 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
18:47:30.940 T:1958748160 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
18:47:30.964 T:1958748160 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:47:30.964 T:1958748160 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Do not modify! These are OSMC Optimised Settings for your device !-->
<!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !-->
<!-- It will override these settings, and your settings will be preserved across OSMC updates !-->
<advancedsettings>
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
<handlemounting>0</handlemounting>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
18:47:30.966 T:1958748160 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:47:30.966 T:1958748160 NOTICE: Default Video Player: VideoPlayer
18:47:30.966 T:1958748160 NOTICE: Default Audio Player: paplayer
18:47:30.966 T:1958748160 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:47:30.966 T:1958748160 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:47:30.973 T:1958748160 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:47:30.974 T:1958748160 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:47:30.976 T:1958748160 NOTICE: Loaded playercorefactory configuration
18:47:30.976 T:1958748160 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:47:30.976 T:1958748160 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:47:31.111 T:1958748160 NOTICE: Running database version Addons27
18:47:31.942 T:1958748160 NOTICE: ADDONS: Using repository repository.xbmc.org
18:47:32.210 T:1958748160 NOTICE: Raspberry PI firmware version: Sep 22 2017 21:36:43
Copyright (c) 2012 Broadcom
version f5217b8887607d0dd890a434de9c73d9aa9a7c0f (clean) (release)
18:47:32.211 T:1958748160 NOTICE: ARM mem: 768MB GPU mem: 256MB MPG2:0 WVC1:0
18:47:32.211 T:1958748160 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
18:47:32.211 T:1958748160 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x13d62
over_voltage_avs_boost=0x13d62
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
sdtv_aspect=1
temp_limit=85
device_tree=-
18:47:32.220 T:1958748160 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:47:32.222 T:1958748160 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
18:47:32.222 T:1958748160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
18:47:32.223 T:1958748160 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
18:47:32.223 T:1958748160 NOTICE: Found (1920x1080@50.000000) at 26, setting to RES_DESKTOP at 16
18:47:32.223 T:1958748160 NOTICE: Checking resolution 22
18:47:32.527 T:1958748160 NOTICE: GL_VENDOR = Broadcom
18:47:32.528 T:1958748160 NOTICE: GL_RENDERER = VideoCore IV HW
18:47:32.528 T:1958748160 NOTICE: GL_VERSION = OpenGL ES 2.0
18:47:32.528 T:1958748160 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:47:32.528 T:1958748160 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:47:34.091 T:1830810608 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:47:34.101 T:1938813936 NOTICE: Running database version Addons27
18:47:34.107 T:1938813936 NOTICE: Running database version ViewModes6
18:47:34.109 T:1938813936 NOTICE: Running database version Textures13
18:47:34.120 T:1938813936 NOTICE: Running database version MyMusic60
18:47:34.136 T:1938813936 NOTICE: Running database version MyVideos107
18:47:34.142 T:1938813936 NOTICE: Running database version TV29
18:47:34.144 T:1938813936 NOTICE: Running database version Epg11
18:47:34.146 T:1958748160 NOTICE: start dvd mediatype detection
18:47:34.923 T:1958748160 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:47:37.080 T:1958748160 NOTICE: UpdateLibraries: Starting video library startup scan
18:47:37.249 T:1958748160 NOTICE: initialize done
18:47:37.249 T:1958748160 NOTICE: Running the application...
18:47:37.257 T:1958748160 NOTICE: starting zeroconf publishing
18:47:37.258 T:1958748160 NOTICE: CWebServer[8080]: Started
18:47:37.258 T:1958748160 NOTICE: starting upnp client
18:47:37.263 T:1562371056 NOTICE: ES: Starting UDP Event server on port 9777
18:47:37.264 T:1562371056 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
18:47:52.511 T:1700045808 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
18:47:57.835 T:1629479920 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-17.5), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
18:48:03.531 T:1512039408 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/Československá televize.png
18:48:04.488 T:1708434416 WARNING: CSkinInfo: failed to load skin settings
18:49:31.758 T:1958748160 NOTICE: Samba is idle. Closing the remaining connections
18:50:07.150 T:1671734256 NOTICE: VideoInfoScanner: Starting scan ..
18:51:23.579 T:1958748160 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
18:51:32.572 T:1671734256 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=Dark%20by%20Noon|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTAxNjM0OTEsImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTEwMDc3MDkxfQ.sUvNlYsMxAPz7jE7TMXQbotbgzlIVmwbW6eP0I0pua96oI2_1A3uvk_goO81wXFTaeP_yu0T_CxViFUpm0ezILqbHgUTyUOkE3HTDrF6d4gfwqB436ACDagcerWhiPnt960OMCS2U3ALkZLTE6G67OVMHz8OZVpDXDb2r3AScT2k4Bx7cxeKGjtf-9V1A4dIQBPsJsANgPhqjHMwnC8a9OxG0LWUCiBPcquxEJU9n8IIyxKPKLAYEPvmBWqnjQeaR-7Zr-zZ_eBo9G04pRUWAWkKvxZnN6OlCbNOlZaVYHuDpxqQot8zOrgQhVUWWFPLWv533kUOs2g6rvtw74PAhg&Accept-Language=de
18:51:32.572 T:1671734256 ERROR: Run: Unable to parse web site
18:51:33.385 T:1671734256 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=Dark%20by%20Noon|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTAxNjM0OTEsImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTEwMDc3MDkxfQ.sUvNlYsMxAPz7jE7TMXQbotbgzlIVmwbW6eP0I0pua96oI2_1A3uvk_goO81wXFTaeP_yu0T_CxViFUpm0ezILqbHgUTyUOkE3HTDrF6d4gfwqB436ACDagcerWhiPnt960OMCS2U3ALkZLTE6G67OVMHz8OZVpDXDb2r3AScT2k4Bx7cxeKGjtf-9V1A4dIQBPsJsANgPhqjHMwnC8a9OxG0LWUCiBPcquxEJU9n8IIyxKPKLAYEPvmBWqnjQeaR-7Zr-zZ_eBo9G04pRUWAWkKvxZnN6OlCbNOlZaVYHuDpxqQot8zOrgQhVUWWFPLWv533kUOs2g6rvtw74PAhg&Accept-Language=en
18:51:33.386 T:1671734256 ERROR: Run: Unable to parse web site
18:51:34.213 T:1671734256 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=Dark%20by%20Noon|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTAxNjM0OTEsImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTEwMDc3MDkxfQ.sUvNlYsMxAPz7jE7TMXQbotbgzlIVmwbW6eP0I0pua96oI2_1A3uvk_goO81wXFTaeP_yu0T_CxViFUpm0ezILqbHgUTyUOkE3HTDrF6d4gfwqB436ACDagcerWhiPnt960OMCS2U3ALkZLTE6G67OVMHz8OZVpDXDb2r3AScT2k4Bx7cxeKGjtf-9V1A4dIQBPsJsANgPhqjHMwnC8a9OxG0LWUCiBPcquxEJU9n8IIyxKPKLAYEPvmBWqnjQeaR-7Zr-zZ_eBo9G04pRUWAWkKvxZnN6OlCbNOlZaVYHuDpxqQot8zOrgQhVUWWFPLWv533kUOs2g6rvtw74PAhg&Accept-Language=de
18:51:34.214 T:1671734256 ERROR: Run: Unable to parse web site
18:51:34.543 T:1671734256 ERROR: CCurlFile::Open failed with code 404 for https://api.thetvdb.com/search/series?name=Dark%20by%20Noon|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTAxNjM0OTEsImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTEwMDc3MDkxfQ.sUvNlYsMxAPz7jE7TMXQbotbgzlIVmwbW6eP0I0pua96oI2_1A3uvk_goO81wXFTaeP_yu0T_CxViFUpm0ezILqbHgUTyUOkE3HTDrF6d4gfwqB436ACDagcerWhiPnt960OMCS2U3ALkZLTE6G67OVMHz8OZVpDXDb2r3AScT2k4Bx7cxeKGjtf-9V1A4dIQBPsJsANgPhqjHMwnC8a9OxG0LWUCiBPcquxEJU9n8IIyxKPKLAYEPvmBWqnjQeaR-7Zr-zZ_eBo9G04pRUWAWkKvxZnN6OlCbNOlZaVYHuDpxqQot8zOrgQhVUWWFPLWv533kUOs2g6rvtw74PAhg&Accept-Language=en
18:51:34.544 T:1671734256 ERROR: Run: Unable to parse web site
18:51:34.545 T:1671734256 WARNING: No information found for item 'smb://DISKSTATION/video/SERIEN/Dark by Noon (2013)/', it won't be added to the library.
18:52:11.422 T:1671734256 WARNING: Process directory 'smb://DISKSTATION/video/SERIEN/Banshee/' does not exist - skipping scan.
18:52:11.425 T:1671734256 WARNING: Process directory 'smb://DISKSTATION/video/SERIEN/Columbo/' does not exist - skipping scan.
18:52:11.428 T:1671734256 WARNING: Process directory 'smb://DISKSTATION/video/SERIEN/Republic of Doyle/' does not exist - skipping scan.
18:52:11.452 T:1671734256 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 02:04
18:52:11.489 T:1958748160 WARNING: CreateLoader - unsupported protocol(sources) in sources://music.tbn
18:52:12.913 T:1671734256 ERROR: GetDirectory - Error getting
18:53:31.538 T:1958748160 ERROR: Previous line repeats 10 times.
18:53:31.539 T:1958748160 NOTICE: CleanDatabase: Starting videodatabase cleanup ..
Greats
Frank
We need full debugging logs, please
