RPI3 not mounting drives after September update
Hello, just updated to the September update on my RPI3 and now my external drives are not mounting any more.
When connected to the system via SSH, “sudo apt-get dist-upgrade” gives:
Reading package lists… Done
Building dependency tree
Calculating upgrade… Done
The following packages have been kept back:
rbp2-device-osmc
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
While “sudo apt-get install rbp2-device-osmc” gives:
osmc@osmc:~$ sudo apt-get install rbp2-device-osmc
rbp2-device-osmc : Depends: armv7-diskmount-osmc but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
While “sudo apt-get install armv7-diskmount-osmc” gives:
osmc@osmc:~$ sudo apt-get install armv7-diskmount-osmc
armv7-diskmount-osmc : Depends: armv7-udisks-osmc but it is not installable
Depends: armv7-udisks-glue-osmc but it is not installable
Did you maybe forget to upload thse packages to the package server?
Btw trying to reinstall the rbp2-device-osmc 1.4.1 package like suggested in other topics gives:
osmc@osmc:~$ sudo apt-get install --reinstall rbp2-device-osmc=1.4.1
Reinstallation of rbp2-device-osmc is not possible, it cannot be downloaded.
Same issue here - same log outputs above apply
[September update on RPI3]
What log outputs?
We’d need to see full debug logs to be able to troubleshoot this further.
Here they are http://paste.osmc.tv/tozudutupa
Same problem here!
This should now be fixed. Please try updating again in ten minutes
You can do this manually by reading Keeping your OSMC system up to date - General - OSMC.
Sorry for the inconvenience
Please let me know if you still experience any problems.
No dice.
Reading package lists... Done
Calculating upgrade... Done
  rbp2-device-osmc
osmc@osmc:~$
Same here, before sam’s post and now:
Same with apt dist-upgrade
EDIT: Works now (3 minutes later), thank you
You re ran dist-upgrade but it doesn’t look like you checked for updates, ie apt-get update.
We recommend updating via My OSMC instead of the command line if you’re not sure how to do this.
Scratch that, it’s working!
Drives are back up for me, thanks Sam!
The following packages will be REMOVED:
  diskmount-osmc udisks udisks-glue
  armv7-diskmount-osmc armv7-udisks-glue-osmc armv7-udisks-osmc
Yep, it’s working now! Thanks!
Thanks Sam! worked here too !
That solved this problem for me as well.
And as always, thanks for this great product!
