Hi Graham,
I had done that. Here is what I have:
osmc@osmc-Barnaby:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
kefmuo
MUO
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
Something not right as there are no colons.
Here is my .asoundrc:-
osmc@osmc-Barnaby:~$ cat .asoundrc
# This file describes the bluetooth sinks available for Kodi to play to
# add lines like the following for each BT device (speaker or headphones)
pcm.kefmuo {
type plug
slave.pcm {
type bluealsa
device "40:EF:4C:CC:DE:9E"
profile "a2dp"
hint { show on description "MUO"}
# using the MAC of the device (see bluetoothctl) instead of 12:34:56:78:9A:BC
# Use any letters or numbers for the description which will show up in Settings-System-Audio
Here is what I have in Audio Output section of my /etc/mpd.conf:-
# An example of an ALSA output:
audio_output {
type "alsa"
name "MUO"
device "hw:0,2" # optional
# mixer_type "hardware" # optional
# mixer_device "default" # optional
# mixer_control "PCM" # optional
# mixer_index "0" # optional
Clearly this isn’t correct and I am groping in the dark. There are very many options in this file so shall need your help here but none of my more obvious attempts worked and I don’t think mpd is playing but some other sound source which then always goes to HDMI.
