RPI3 - Stretch test - IR not working
After upgrade to stretch I noticed my IR remote stop working in my RPI3, this is a USB receiver and worked fine before, in fact in noobs menu works, but after OSMC came up stop working, is not the same with others OS. This is the dmseg related to IR reconnection:
Blockquote
715.390238] usb 1-1.2: USB disconnect, device number 4
[ 735.109850] usb 1-1.2: new low-speed USB device number 6 using dwc_otg
[ 735.346523] usb 1-1.2: config 1 interface 0 altsetting 0 has 2 endpoint descriptors, different from the interface descriptor’s value: 1
[ 735.376048] usb 1-1.2: New USB device found, idVendor=073a, idProduct=2330
[ 735.376069] usb 1-1.2: New USB device strings: Mfr=2, Product=2, SerialNumber=2
[ 735.376078] usb 1-1.2: Product: www.tigerfly.net
[ 735.376086] usb 1-1.2: Manufacturer: www.tigerfly.net
[ 735.376094] usb 1-1.2: SerialNumber: www.tigerfly.net
[ 735.450386] input: www.tigerfly.net www.tigerfly.net as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:073A:2330.0002/input/input3
[ 735.522090] hid-generic 0003:073A:2330.0002: input,hidraw0: USB HID v1.10 Keyboard [www.tigerfly.net www.tigerfly.net] on usb-3f980000.usb-1.2/input0
I tested several remotes configuration in MyOSMC with success, any idea?
thanks
