I have 2 RPi3’s and a Vero 4k so I’ll just post this in RPi
I can’t seem to get my OpenVPN to function.
I tried this
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install network-manger-openvpn
sudo apt-get install openvpn
Run sudo wget https://www.yourVPNprovidergoeshere.com/openvpn/openvpn.zip
Extract the files from the zip with unzip openvpn.zipNow try and connect to the VPN of your choice ending in ovpn.
sudo openvpn --config ./Netherlands.ovpn
It’ll ask you for your user and password. Enter these and hopefully you get 'Initialization Sequence Completed’. If not, go over the process before.
On the Raspberry Pi you need to press ‘CTRL -c’ to cancel the sequence and take control again.
After this you need to change the config to keep your User and Password in it.
sudo nano /etc/openvpn/login.confhere you need 2 lines
USERNAME- add your credentials
PASSWORD- add your credentials
now
sudo chmod 400 /etc/openvpn/login.confAnd now make a copy of the .ovpn config file and add the login.conf file onto the existing line with auth-user-pass. The * depicts the .opvn file of your choice.
sudo cp .ovpn /etc/openvpn/.conf
so: sudo nano /etc/openvpn/*.conf
At the line auth-user-pass add login.conf so it looks exactly like
auth-user-pass login.conf
Now the important part. Move both the ca.crtfile and the crl.pem file into /etc/openvpn folder.
Run another test to make sure your username and password are automatically accepted by running:
sudo openvpn *.conf
You should get the 'Initialization Sequence Completed’ again and no interaction. Please CTRL -c’ out of it.
To make it work on start up we need to change the startup file for openvpn.
sudo nano /etc/default/openvpnLook down the file for these lines:
Add the name of your VPN WITHOUT .opvn extension. For me its Netherlands#AUTOSTART=“all”
#AUTOSTART=“none”
#AUTOSTART="home office”
AUTOSTART=“Netherlands”Now reboot your Pi:
sudo reboot
Then to make sure it’s working find my external IP
wget http://ipecho.net/plain -O - -q ; echo
Which forces all LAN IP’s (vero and Rpi’s) to the same LAN IP 192.168.1.102 which I use on my main computer so it keeps kicking me off. If I try to set /network/interfaces to a static IP and test my ovpn it gets a Linux routing error because of it, I tried to set a static DHCP from my router but that causes a routing error as well.
If I wget http://ipecho.net/plain - O - -q ; echo while not changing the routing it returns nothing and has no access to the internet.
I tried using the Brian Hornsby addon afterwards and followed his tutorial, if I check ipecho after that it worked and my IP returned is right, but if I check again after about an hour it returns my home IP again while the addon still says I’m connected.
I didn’t even reach setting iptables because the connection isn’t stable, if I can get it to stabilize I would need iptable settings as well because I’m no hero when it comes to iptables.
Does anyone know how to get this to work?
Making a hotspot shield or router setup is not an option unfortunately so I have to get them to work on each device (no i’m not using it on more then the allowed clients from the VPN service) but I just can’t seem to figure out why it screws up. It works fine on openelec but I don’t like using openelec.
