I’m getting a kernel oops on startup that is similar to https://patchwork.kernel.org/patch/10282365/
I updated an instance on my pi3 then cloned it.
Any thoughts ?
So, looking closer at my oops screenshot.
It was the snmpd process that triggered it in my case.
I’ve disabled snmpd and it now appears to work fine.
I suspect we still have the bug I refererenced above, but snmpd seems to start early in the boot process (S02snmpd) and is probably similarly triggering the issue.
Hi @penfold42 . I hope you’re doing well.
I’ve added the patch as a precaution. Can you give it a test?
Login via the command line
Edit the file /etc/apt/sources.list
Add the following line: deb http://apt.osmc.tv stretch-devel main
Thanks for the quick work.
it took a few hours for the updated kernel to appear - CDN network delay ?
It appears to have worked.
thanks!
I may have been too hasty… whilst the box boots fine, what i didnt realise until now is that ethernet doesnt work.
the gui thinks “Status: No wired connection”
grab-logs -A are at https://paste.osmc.tv/yoqecicefo
Nov 04 04:16:42 newpi3.home systemd[1]: networking.service: Cannot add dependency job, ignoring: Unit networking.service is masked.
What’s the output from running systemctl status networking.service ?
I’m not sure if the patch is suitable.
It would be good if others could try it and comment
What’s the easiest way to roll back the kernel ?
# systemctl status networking.service
● networking.service
Loaded: masked (/dev/null; bad)
Active: inactive (dead)
Not sure if this is the “right” way to do it, but I just did:
cp /boot/vmlinuz-4.14.26-2-osmc /boot/kernel.img
Seems to have done the trick and now i have wired ethernet back (with no snmpd)
Almost. There’s one more step to do.
You need to cd to /boot and remove all the bcm-xxxxx.dtb files and the overlays directory + its contents (sudo rm -r overlays)
Then (using sudo) you need to copy the bcm-xxxxx.dtb files and overlays directory + its contents from /boot/dtb-4.14.26-2-osmc to /boot.
Thanks !
I guess I’m lucky for now - such a minor kernel rollback, there might not have been any significant differences in the overlays
Indeed. Your new kernel might have contained a few other small changes but overall was a minor update.
committed 04:10PM - 04 Apr 18 UTC
When using wicked with a lan78xx device attached to the system, we
end up with e… thtool commands issued on the device before an ifup
got issued. That lead to the following crash:
Unable to handle kernel NULL pointer dereference at virtual address 0000039c
pgd = ffff800035b30000
[0000039c] *pgd=0000000000000000
Internal error: Oops: 96000004 [#1] SMP
Modules linked in: [...]
Supported: Yes
CPU: 3 PID: 638 Comm: wickedd Tainted: G E 4.12.14-0-default #1
Hardware name: raspberrypi rpi/rpi, BIOS 2018.03-rc2 02/21/2018
task: ffff800035e74180 task.stack: ffff800036718000
PC is at phy_ethtool_ksettings_get+0x20/0x98
LR is at lan78xx_get_link_ksettings+0x44/0x60 [lan78xx]
pc : [<ffff0000086f7f30>] lr : [<ffff000000dcca84>] pstate: 20000005
sp : ffff80003671bb20
x29: ffff80003671bb20 x28: ffff800035e74180
x27: ffff000008912000 x26: 000000000000001d
x25: 0000000000000124 x24: ffff000008f74d00
x23: 0000004000114809 x22: 0000000000000000
x21: ffff80003671bbd0 x20: 0000000000000000
x19: ffff80003671bbd0 x18: 000000000000040d
x17: 0000000000000001 x16: 0000000000000000
x15: 0000000000000000 x14: ffffffffffffffff
x13: 0000000000000000 x12: 0000000000000020
x11: 0101010101010101 x10: fefefefefefefeff
x9 : 7f7f7f7f7f7f7f7f x8 : fefefeff31677364
x7 : 0000000080808080 x6 : ffff80003671bc9c
x5 : ffff80003671b9f8 x4 : ffff80002c296190
x3 : 0000000000000000 x2 : 0000000000000000
x1 : ffff80003671bbd0 x0 : ffff80003671bc00
Process wickedd (pid: 638, stack limit = 0xffff800036718000)
Call trace:
Exception stack(0xffff80003671b9e0 to 0xffff80003671bb20)
b9e0: ffff80003671bc00 ffff80003671bbd0 0000000000000000 0000000000000000
ba00: ffff80002c296190 ffff80003671b9f8 ffff80003671bc9c 0000000080808080
ba20: fefefeff31677364 7f7f7f7f7f7f7f7f fefefefefefefeff 0101010101010101
ba40: 0000000000000020 0000000000000000 ffffffffffffffff 0000000000000000
ba60: 0000000000000000 0000000000000001 000000000000040d ffff80003671bbd0
ba80: 0000000000000000 ffff80003671bbd0 0000000000000000 0000004000114809
baa0: ffff000008f74d00 0000000000000124 000000000000001d ffff000008912000
bac0: ffff800035e74180 ffff80003671bb20 ffff000000dcca84 ffff80003671bb20
bae0: ffff0000086f7f30 0000000020000005 ffff80002c296000 ffff800035223900
bb00: 0000ffffffffffff 0000000000000000 ffff80003671bb20 ffff0000086f7f30
[<ffff0000086f7f30>] phy_ethtool_ksettings_get+0x20/0x98
[<ffff000000dcca84>] lan78xx_get_link_ksettings+0x44/0x60 [lan78xx]
[<ffff0000087cbc40>] ethtool_get_settings+0x68/0x210
[<ffff0000087cc0d4>] dev_ethtool+0x214/0x2180
[<ffff0000087e5008>] dev_ioctl+0x400/0x630
[<ffff00000879dd00>] sock_do_ioctl+0x70/0x88
[<ffff00000879f5f8>] sock_ioctl+0x208/0x368
[<ffff0000082cde10>] do_vfs_ioctl+0xb0/0x848
[<ffff0000082ce634>] SyS_ioctl+0x8c/0xa8
Exception stack(0xffff80003671bec0 to 0xffff80003671c000)
bec0: 0000000000000009 0000000000008946 0000fffff4e841d0 0000aa0032687465
bee0: 0000aaaafa2319d4 0000fffff4e841d4 0000000032687465 0000000032687465
bf00: 000000000000001d 7f7fff7f7f7f7f7f 72606b622e71ff4c 7f7f7f7f7f7f7f7f
bf20: 0101010101010101 0000000000000020 ffffffffffffffff 0000ffff7f510c68
bf40: 0000ffff7f6a9d18 0000ffff7f44ce30 000000000000040d 0000ffff7f6f98f0
bf60: 0000fffff4e842c0 0000000000000001 0000aaaafa2c2e00 0000ffff7f6ab000
bf80: 0000fffff4e842c0 0000ffff7f62a000 0000aaaafa2b9f20 0000aaaafa2c2e00
bfa0: 0000fffff4e84818 0000fffff4e841a0 0000ffff7f5ad0cc 0000fffff4e841a0
bfc0: 0000ffff7f44ce3c 0000000080000000 0000000000000009 000000000000001d
bfe0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
The culprit is quite simple: The driver tries to access the phy left and right,
but only actually has a working reference to it when the device is up.
The fix thus is quite simple too: Get a reference to the phy on probe already
and keep it even when the device is going down.
With this patch applied, I can successfully run wicked on my system and bring
the interface up and down as many times as I want, without getting NULL pointer
dereferences in between.
Signed-off-by: Alexander Graf <agraf@suse.de>
And some other commits last night claim to fix the issue
Waiting for a couple of improvements yet before I’ll make any further testing available.
