Hello,
It seems that 06/2023 update isn’t very friendly with Rpi3b+ & his embedded WiFi card.
It seems to be a conflict between WiFi driver & 5.15.83-3 Kernel.
So after playing over 5-6h of video (cumulated, with no reboot), all the network stack crash.
I suppose that it can be faster with an iperf test, but I didn’t test yet.
I can exclude some possible causes like :
Problem between 2.4Ghz & 5Ghz => Tested on 2.4Ghz & 5Ghz with 2 differents SSID
WiFi country parameter (crda package deployed & configured with my WiFi region => No effect)
Material problem => tested on 2 two differents Rpi 3b+ => LAN no problem => WiFi crash
What hasn’t be tested => Make a fresh install (not upgraded from previous versions) & show what happens.
And to conclude, here is the kernel trace:
Jun 29 14:47:48 osmc kernel: [69143.488511] kworker/u9:0: page allocation failure: order:0, mode:0x800(GFP_NOWAIT), nodemask=(null),cpuset=/,mems_allowed=0
Jun 29 14:47:48 osmc kernel: [69143.488592] CPU: 0 PID: 67 Comm: kworker/u9:0 Tainted: G C 5.15.83-3-osmc #1
Jun 29 14:47:48 osmc kernel: [69143.488603] Hardware name: BCM2835
Jun 29 14:47:48 osmc kernel: [69143.488611] Workqueue: brcmf_wq/mmc1:0001:1 brcmf_sdio_dataworker [brcmfmac]
Jun 29 14:47:48 osmc kernel: [69143.488886] Backtrace:
Jun 29 14:47:48 osmc kernel: [69143.488895] [<80bdf758>] (dump_backtrace) from [<80bdf9a0>] (show_stack+0x20/0x24)
Jun 29 14:47:48 osmc kernel: [69143.488928] r7:ffffe000 r6:00000000 r5:80e06f74 r4:680f0013
Jun 29 14:47:48 osmc kernel: [69143.488933] [<80bdf980>] (show_stack) from [<80be5014>] (dump_stack_lvl+0x70/0x94)
Jun 29 14:47:48 osmc kernel: [69143.488953] [<80be4fa4>] (dump_stack_lvl) from [<80be5050>] (dump_stack+0x18/0x1c)
Jun 29 14:47:48 osmc kernel: [69143.488970] r7:ffffe000 r6:00000000 r5:80e1b60c r4:00000000
Jun 29 14:47:48 osmc kernel: [69143.488975] [<80be5038>] (dump_stack) from [<803876ec>] (warn_alloc+0x110/0x1b4)
Jun 29 14:47:48 osmc kernel: [69143.488993] [<803875dc>] (warn_alloc) from [<80389028>] (__alloc_pages+0x1898/0x194c)
Jun 29 14:47:48 osmc kernel: [69143.489011] r3:00000000 r2:80e1b60c
Jun 29 14:47:48 osmc kernel: [69143.489019] r7:00000081 r6:00000000 r5:00000800 r4:00000000
Jun 29 14:47:48 osmc kernel: [69143.489023] [<80387790>] (__alloc_pages) from [<8039db40>] (new_slab+0x4cc/0x54c)
Jun 29 14:47:48 osmc kernel: [69143.489055] r10:812057c8 r9:00000000 r8:ffffffff r7:00000020 r6:00000000 r5:81401240
Jun 29 14:47:48 osmc kernel: [69143.489062] r4:00000800
Jun 29 14:47:48 osmc kernel: [69143.489068] [<8039d674>] (new_slab) from [<803a08f0>] (___slab_alloc.constprop.0+0x4d4/0x96c)
Jun 29 14:47:48 osmc kernel: [69143.489092] r9:baa56cc0 r8:00000000 r7:81205814 r6:00000000 r5:81401240 r4:81401240
Jun 29 14:47:48 osmc kernel: [69143.489097] [<803a041c>] (___slab_alloc.constprop.0) from [<803a2e78>] (__kmalloc+0x52c/0x5d0)
Jun 29 14:47:48 osmc kernel: [69143.489119] r10:01ad2b90 r9:00000900 r8:00000000 r7:81205814 r6:00000000 r5:81401240
Jun 29 14:47:48 osmc kernel: [69143.489125] r4:81125cc0
Jun 29 14:47:48 osmc kernel: [69143.489129] [<803a294c>] (__kmalloc) from [<80807fd8>] (bcm2835_dma_create_cb_chain+0x5c/0x3a4)
Jun 29 14:47:48 osmc kernel: [69143.489155] r10:40000000 r9:00000000 r8:7e300020 r7:00000000 r6:8174ac40 r5:00000002
Jun 29 14:47:48 osmc kernel: [69143.489161] r4:00000001
Jun 29 14:47:48 osmc kernel: [69143.489165] [<80807f7c>] (bcm2835_dma_create_cb_chain) from [<80808888>] (bcm2835_dma_prep_slave_sg+0x148/0x3bc)
Jun 29 14:47:48 osmc kernel: [69143.489185] r10:40000000 r9:00000000 r8:00000000 r7:00000001 r6:8174ac40 r5:81c19c50
Jun 29 14:47:48 osmc kernel: [69143.489191] r4:00000001
Jun 29 14:47:48 osmc kernel: [69143.489195] [<80808740>] (bcm2835_dma_prep_slave_sg) from [<809b7a04>] (bcm2835_mmc_transfer_dma+0xf0/0x23c)
Jun 29 14:47:48 osmc kernel: [69143.489217] r10:b097c400 r9:80808740 r8:00000001 r7:00000002 r6:00000000 r5:8174ac40
Jun 29 14:47:48 osmc kernel: [69143.489223] r4:81429b40
Jun 29 14:47:48 osmc kernel: [69143.489227] [<809b7914>] (bcm2835_mmc_transfer_dma) from [<809b8414>] (bcm2835_mmc_request+0xa8/0xc8)
Jun 29 14:47:48 osmc kernel: [69143.489246] r9:00000000 r8:00000003 r7:680f0013 r6:81429b40 r5:81c19c98 r4:81429800
Jun 29 14:47:48 osmc kernel: [69143.489251] [<809b836c>] (bcm2835_mmc_request) from [<80996ad0>] (__mmc_start_request+0x88/0x1c4)
Jun 29 14:47:48 osmc kernel: [69143.489270] r7:81c19ca8 r6:81c19c98 r5:81c19c98 r4:81429800
Jun 29 14:47:48 osmc kernel: [69143.489275] [<80996a48>] (__mmc_start_request) from [<80996ca0>] (mmc_start_request+0x94/0xbc)
Jun 29 14:47:48 osmc kernel: [69143.489293] r7:81c19ca8 r6:00000000 r5:81c19c98 r4:81429800
Jun 29 14:47:48 osmc kernel: [69143.489297] [<80996c0c>] (mmc_start_request) from [<80996de0>] (mmc_wait_for_req+0x78/0x150)
Jun 29 14:47:48 osmc kernel: [69143.489315] r7:81c19ca8 r6:8142a800 r5:81c19c98 r4:81429800
Jun 29 14:47:48 osmc kernel: [69143.489320] [<80996d68>] (mmc_wait_for_req) from [<809a55e4>] (mmc_io_rw_extended+0x22c/0x338)
Jun 29 14:47:48 osmc kernel: [69143.489339] r7:00000001 r6:8142a800 r5:00080000 r4:00000600
Jun 29 14:47:48 osmc kernel: [69143.489344] [<809a53b8>] (mmc_io_rw_extended) from [<809a74c4>] (sdio_io_rw_ext_helper+0x1e8/0x338)
Jun 29 14:47:48 osmc kernel: [69143.489364] r10:00000000 r9:00008000 r8:b097ca00 r7:81e6e400 r6:8142a800 r5:00000000
Jun 29 14:47:48 osmc kernel: [69143.489370] r4:000001ff
Jun 29 14:47:48 osmc kernel: [69143.489375] [<809a72dc>] (sdio_io_rw_ext_helper) from [<809a7644>] (sdio_readsb+0x30/0x38)
Jun 29 14:47:48 osmc kernel: [69143.489395] r10:7f36e1c4 r9:18000000 r8:b80720c0 r7:18000000 r6:84f96c00 r5:84f96c00
Jun 29 14:47:48 osmc kernel: [69143.489401] r4:b80720c0
Jun 29 14:47:48 osmc kernel: [69143.489405] [<809a7614>] (sdio_readsb) from [<7f358834>] (brcmf_sdiod_skbuff_read+0xd4/0xec [brcmfmac])
Jun 29 14:47:48 osmc kernel: [69143.489605] [<7f358760>] (brcmf_sdiod_skbuff_read [brcmfmac]) from [<7f359944>] (brcmf_sdiod_recv_pkt+0xcc/0xf8 [brcmfmac])
Jun 29 14:47:48 osmc kernel: [69143.489982] r5:b097c400 r4:00000000
Jun 29 14:47:48 osmc kernel: [69143.489986] [<7f359878>] (brcmf_sdiod_recv_pkt [brcmfmac]) from [<7f3550c0>] (brcmf_sdio_dataworker+0x1030/0x2884 [brcmfmac])
Jun 29 14:47:48 osmc kernel: [69143.490368] r9:84f97268 r8:00000200 r7:00000004 r6:b097ca00 r5:b097c400 r4:b80720c0
Jun 29 14:47:48 osmc kernel: [69143.490374] [<7f354090>] (brcmf_sdio_dataworker [brcmfmac]) from [<8014b988>] (process_one_work+0x214/0x5a8)
Jun 29 14:47:48 osmc kernel: [69143.490579] r10:81434605 r9:00000120 r8:000a001a r7:81434600 r6:81766e00 r5:81d2e200
Jun 29 14:47:48 osmc kernel: [69143.490585] r4:84f97268
Jun 29 14:47:48 osmc kernel: [69143.490590] [<8014b774>] (process_one_work) from [<8014bd80>] (worker_thread+0x64/0x5fc)
Jun 29 14:47:48 osmc kernel: [69143.490610] r10:81766e00 r9:00000088 r8:81203d00 r7:81766e18 r6:81d2e218 r5:81766e00
Jun 29 14:47:48 osmc kernel: [69143.490616] r4:81d2e200
Jun 29 14:47:48 osmc kernel: [69143.490620] [<8014bd1c>] (worker_thread) from [<8015575c>] (kthread+0x16c/0x1a0)
Jun 29 14:47:48 osmc kernel: [69143.490643] r10:81697260 r9:8151bcfc r8:81c18000 r7:81d2e200 r6:8014bd1c r5:81697240
Jun 29 14:47:48 osmc kernel: [69143.490650] r4:81d28780
Jun 29 14:47:48 osmc kernel: [69143.490654] [<801555f0>] (kthread) from [<801000d4>] (ret_from_fork+0x14/0x20)
Jun 29 14:47:48 osmc kernel: [69143.490672] Exception stack(0x81c19fb0 to 0x81c19ff8)
Jun 29 14:47:48 osmc kernel: [69143.490681] 9fa0: 00000000 00000000 00000000 00000000
Jun 29 14:47:48 osmc kernel: [69143.490692] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Jun 29 14:47:48 osmc kernel: [69143.490701] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Jun 29 14:47:48 osmc kernel: [69143.490712] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:801555f0
Jun 29 14:47:48 osmc kernel: [69143.490719] r4:81d28780 r3:00000000
Jun 29 14:47:48 osmc kernel: [69143.490795] Mem-Info:
Jun 29 14:47:48 osmc kernel: [69143.490809] active_anon:181 inactive_anon:53060 isolated_anon:0
Jun 29 14:47:48 osmc kernel: [69143.490809] active_file:3494 inactive_file:2010 isolated_file:0
Jun 29 14:47:48 osmc kernel: [69143.490809] unevictable:352 dirty:2 writeback:0
Jun 29 14:47:48 osmc kernel: [69143.490809] slab_reclaimable:3202 slab_unreclaimable:71327
Jun 29 14:47:48 osmc kernel: [69143.490809] mapped:4640 shmem:176 pagetables:653 bounce:0
Jun 29 14:47:48 osmc kernel: [69143.490809] kernel_misc_reclaimable:0
Jun 29 14:47:48 osmc kernel: [69143.490809] free:42175 free_pcp:0 free_cma:36604
Jun 29 14:47:48 osmc kernel: [69143.490835] Node 0 active_anon:724kB inactive_anon:212240kB active_file:13976kB inactive_file:8040kB unevictable:1408kB isolated(anon):0kB isolated(file):0kB mapped:18560kB dirty:8kB writeback:0kB shmem:704kB writeback_tmp:0kB kernel_stack:1592kB pagetables:2612kB all_unreclaimable? no
Jun 29 14:47:48 osmc kernel: [69143.490858] DMA free:168700kB min:12288kB low:15360kB high:18432kB reserved_highatomic:0KB active_anon:724kB inactive_anon:212240kB active_file:13952kB inactive_file:7912kB unevictable:1408kB writepending:8kB present:970752kB managed:943756kB mlocked:1408kB bounce:0kB free_pcp:4kB local_pcp:0kB free_cma:146416kB
Jun 29 14:47:48 osmc kernel: [69143.490883] lowmem_reserve: 0 0 0
Jun 29 14:47:48 osmc kernel: [69143.490915] DMA: 28094kB (UMEC) 14328kB (UMEC) 67516kB (UMEC) 71432kB (UMEC) 32064kB (UMEC) 128128kB (MC) 66256kB (C) 14512kB (C) 71024kB (C) 22048kB (C) 10*4096kB (C) = 169492kB
Jun 29 14:47:48 osmc kernel: [69143.491098] 5970 total pagecache pages
Jun 29 14:47:48 osmc kernel: [69143.491105] 0 pages in swap cache
Jun 29 14:47:48 osmc kernel: [69143.491113] Swap cache stats: add 0, delete 0, find 0/0
Jun 29 14:47:48 osmc kernel: [69143.491122] Free swap = 0kB
Jun 29 14:47:48 osmc kernel: [69143.491129] Total swap = 0kB
Jun 29 14:47:48 osmc kernel: [69143.491136] 242688 pages RAM
Jun 29 14:47:48 osmc kernel: [69143.491143] 0 pages HighMem/MovableOnly
Jun 29 14:47:48 osmc kernel: [69143.491150] 6749 pages reserved
Jun 29 14:47:48 osmc kernel: [69143.491158] 131072 pages cma reserved
Jun 29 14:47:48 osmc kernel: [69143.491177] SLUB: Unable to allocate memory on node -1, gfp=0x900(GFP_NOWAIT|__GFP_ZERO)
Jun 29 14:47:48 osmc kernel: [69143.491193] cache: kmalloc-128, object size: 128, buffer size: 128, default order: 0, min order: 0
Jun 29 14:47:48 osmc kernel: [69143.491206] node 0: slabs: 44023, objs: 1408736, free: 0
Jun 29 14:47:59 osmc kernel: [69153.938805] mmc1: Timeout waiting for hardware interrupt.
Jun 29 14:50:27 osmc kernel: [69302.419317] INFO: task kworker/u9:0:67 blocked for more than 122 seconds.
Regards,
