**Describe the bug**
When I try to do anything related to containers in RPi, th…e software fails and messages that there is no memory cgroup. This issue comes from here: https://github.com/rancher/k3s/issues/1825
**To reproduce**
5.4.42-v7+ kernel, Raspbian 10 buster, only affecting 3B+ and 3B versions, at least not in the Pi 4.
**Expected behaviour**
Software to install successfully and allow management of containers
**Actual behaviour**
Printing of error messages related to cgroups
**System**
System Information
Raspberry Pi 3 Model B Plus Rev 1.3
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
Raspberry Pi reference 2020-02-13
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 5f884374b6ac6e155330c58caa1fb7249b8badf1, stage2
Linux K3sNode2 5.4.42-v7+ #1319 SMP Wed May 20 14:06:11 BST 2020 armv7l GNU/Linux
Revision : a020d3
Serial : 00000000a3b1c042
Model : Raspberry Pi 3 Model B Plus Rev 1.3
Throttled flag : throttled=0x0
Camera : supported=0 detected=0
Videocore information
May 19 2020 22:31:46
Copyright (c) 2012 Broadcom
version ba3a9fd1ea954b440ddea12f8f2b37b7ec1a2e23 (clean) (release) (start_cd)
alloc failures: 0
compactions: 0
legacy block fails: 0
Filesystem information
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 61112892 2034076 56564348 4% /
devtmpfs 466624 0 466624 0% /dev
tmpfs 499904 0 499904 0% /dev/shm
tmpfs 499904 6612 493292 2% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 499904 0 499904 0% /sys/fs/cgroup
/dev/mmcblk0p1 258095 54326 203769 22% /boot
tmpfs 99980 0 99980 0% /run/user/1000
Filename Type Size Used Priority
Package version information
raspberrypi-ui-mods:
Installed: (none)
raspberrypi-sys-mods:
Installed: 20191105
openbox:
Installed: (none)
lxpanel:
Installed: (none)
pcmanfm:
Installed: (none)
rpd-plym-splash:
Installed: (none)
Networking Information
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet x.x.x.x netmask x.x.x.x broadcast x.x.x.x
inet6 y::y.y.y.y prefixlen 64 scopeid 0x20<link>
ether m.m.m.m txqueuelen 1000 (Ethernet)
RX packets 560 bytes 78962 (77.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 231 bytes 30931 (30.2 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
USB Information
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
Display Information
Running Legacy framebuffer
Display: 3
state 0x120000 [TV is off]
device_name=Unk-Composite dis
config.txt
aphy_params_current=819
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x331df0
desired_osc_freq_boost=0x3c45b0
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
dphy_params_current=547
enable_tvout=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_depth=16
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=50000
over_voltage_avs_boost=0x249f0
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
total_mem=1024
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x9a7ec80
device_tree=-
overlay_prefix=overlays/
hdmi_cvt:0=
hdmi_cvt:1=
hdmi_edid_filename:0=
hdmi_edid_filename:1=
hdmi_timings:0=
hdmi_timings:1=
cmdline.txt
coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory
raspi-gpio settings
raspinfo: line 166: raspi-gpio: command not found
vcdbg log messages
Unable to determine the value of __LOG_START
Unable to read logging_header from 0x00000000
dmesg log
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.42-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1319 SMP Wed May 20 14:06:11 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x3a400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 255488
[ 0.000000] Normal zone: 1996 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 255488 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49792 r8192 d23936 u81920
[ 0.000000] pcpu-alloc: s49792 r8192 d23936 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 253492
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 933252K/1021952K available (8192K kernel code, 679K rwdata, 2524K rodata, 1024K init, 824K bss, 23164K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27876 entries in 55 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x4e8 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000292] Console: colour dummy device 80x30
[ 0.000888] printk: console [tty1] enabled
[ 0.000954] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001003] pid_max: default: 32768 minimum: 301
[ 0.001349] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001394] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002586] CPU: Testing write buffer coherency: ok
[ 0.003154] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004101] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004319] rcu: Hierarchical SRCU implementation.
[ 0.005008] smp: Bringing up secondary CPUs ...
[ 0.006126] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007366] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008506] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.008660] smp: Brought up 1 node, 4 CPUs
[ 0.008747] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.008774] CPU: All CPU(s) started in HYP mode.
[ 0.008799] CPU: Virtualization extensions available.
[ 0.009766] devtmpfs: initialized
[ 0.026451] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.026740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026796] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.029833] pinctrl core: initialized pinctrl subsystem
[ 0.031072] NET: Registered protocol family 16
[ 0.035410] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041833] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.041873] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042119] Serial: AMBA PL011 UART driver
[ 0.044082] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.060127] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-05-19 22:31, variant start_cd
[ 0.070141] raspberrypi-firmware soc:firmware: Firmware hash is ba3a9fd1ea954b440ddea12f8f2b37b7ec1a2e23
[ 0.124875] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.127048] SCSI subsystem initialized
[ 0.127345] usbcore: registered new interface driver usbfs
[ 0.127427] usbcore: registered new interface driver hub
[ 0.127576] usbcore: registered new device driver usb
[ 0.129705] clocksource: Switched to clocksource arch_sys_counter
[ 1.284797] VFS: Disk quotas dquot_6.6.0
[ 1.284944] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.285143] FS-Cache: Loaded
[ 1.285414] CacheFiles: Loaded
[ 1.296708] thermal_sys: Registered thermal governor 'step_wise'
[ 1.297093] NET: Registered protocol family 2
[ 1.298148] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.298217] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.298357] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.298567] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.298751] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.298825] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.299135] NET: Registered protocol family 1
[ 1.299893] RPC: Registered named UNIX socket transport module.
[ 1.299924] RPC: Registered udp transport module.
[ 1.299950] RPC: Registered tcp transport module.
[ 1.299975] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.301817] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.305104] Initialise system trusted keyrings
[ 1.305367] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 1.315906] FS-Cache: Netfs 'nfs' registered for caching
[ 1.316562] NFS: Registering the id_resolver key type
[ 1.316634] Key type id_resolver registered
[ 1.316661] Key type id_legacy registered
[ 1.316697] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.317954] Key type asymmetric registered
[ 1.317983] Asymmetric key parser 'x509' registered
[ 1.318050] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.318087] io scheduler mq-deadline registered
[ 1.318114] io scheduler kyber registered
[ 1.321643] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.329854] Console: switching to colour frame buffer device 82x26
[ 1.334047] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.338508] raspberrypi-clk firmware-clocks: CPU frequency range: min 600000000, max 1400000000
[ 1.345135] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.347123] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[ 1.350917] vc-sm: Videocore shared memory driver
[ 1.352921] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.367673] brd: module loaded
[ 1.381127] loop: module loaded
[ 1.384023] Loading iSCSI transport class v2.0-870.
[ 1.386423] libphy: Fixed MDIO Bus: probed
[ 1.388082] usbcore: registered new interface driver lan78xx
[ 1.389771] usbcore: registered new interface driver smsc95xx
[ 1.391270] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.121014] Core Release: 2.80a
[ 2.122517] Setting default values for core params
[ 2.124050] Finished setting default values for core params
[ 2.325936] Using Buffer DMA mode
[ 2.327407] Periodic Transfer Interrupt Enhancement - disabled
[ 2.328879] Multiprocessor Interrupt Enhancement - disabled
[ 2.330342] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.331749] Dedicated Tx FIFOs mode
[ 2.333709] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = ba514000 dma = 0xfa514000 len=9024
[ 2.336464] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.342936] dwc_otg: Microframe scheduler enabled
[ 2.343002] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.344312] WARN::hcd_init_fiq:458: FIQ ASM at 806bc564 length 36
[ 2.345627] WARN::hcd_init_fiq:497: MPHI regs_base at be810000
[ 2.346931] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.348288] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.349710] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.351078] Init: Port Power? op_state=1
[ 2.352390] Init: Power Port (0)
[ 2.354034] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.356664] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.358077] usb usb1: Product: DWC OTG Controller
[ 2.359463] usb usb1: Manufacturer: Linux 5.4.42-v7+ dwc_otg_hcd
[ 2.360902] usb usb1: SerialNumber: 3f980000.usb
[ 2.362925] hub 1-0:1.0: USB hub found
[ 2.364288] hub 1-0:1.0: 1 port detected
[ 2.366305] dwc_otg: FIQ enabled
[ 2.366315] dwc_otg: NAK holdoff enabled
[ 2.366324] dwc_otg: FIQ split-transaction FSM enabled
[ 2.366339] Module dwc_common_port init
[ 2.366666] usbcore: registered new interface driver usb-storage
[ 2.368191] mousedev: PS/2 mouse device common for all mice
[ 2.370912] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.373536] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 600000 KHz
[ 2.377567] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 700000 KHz
[ 2.381945] sdhci: Secure Digital Host Controller Interface driver
[ 2.383234] sdhci: Copyright(c) Pierre Ossman
[ 2.384963] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.386773] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.388270] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.391289] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.392783] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.394277] usbcore: registered new interface driver usbhid
[ 2.395582] usbhid: USB HID core driver
[ 2.397667] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.400542] [vc_sm_connected_init]: start
[ 2.403957] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 2.403964] [vc_sm_connected_init]: failed to initialize shared memory service
[ 2.406557] [vc_sm_connected_init]: end - returning -1
[ 2.409807] Initializing XFRM netlink socket
[ 2.411137] NET: Registered protocol family 17
[ 2.412534] Key type dns_resolver registered
[ 2.414493] Registering SWP/SWPB emulation handler
[ 2.415997] registered taskstats version 1
[ 2.417237] Loading compiled-in X.509 certificates
[ 2.418856] Key type ._fscrypt registered
[ 2.420053] Key type .fscrypt registered
[ 2.431626] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.432889] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.436714] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.439130] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.440397] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.467943] sdhost: log_buf @ (ptrval) (fa513000)
[ 2.506079] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.508899] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.511692] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.515692] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.518545] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.521812] of_cfs_init
[ 2.523046] of_cfs_init: OK
[ 2.526546] Waiting for root device PARTUUID=738a4d67-02...
[ 2.578679] random: fast init done
[ 2.579850] Indeed it is in host mode hprt0 = 00021501
[ 2.664465] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.669913] mmc1: new high speed SDIO card at address 0001
[ 2.671625] mmc0: new high speed SDXC card at address aaaa
[ 2.673539] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 2.677953] mmcblk0: p1 p2
[ 2.704956] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.706046] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.789747] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.789882] Indeed it is in host mode hprt0 = 00001101
[ 3.030038] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.032268] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.034175] hub 1-1:1.0: USB hub found
[ 3.035566] hub 1-1:1.0: 4 ports detected
[ 3.202759] EXT4-fs (mmcblk0p2): recovery complete
[ 3.205912] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.208555] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.218325] devtmpfs: mounted
[ 3.225505] Freeing unused kernel memory: 1024K
[ 3.227188] Run /sbin/init as init process
[ 3.349752] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.480105] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.482841] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.484947] hub 1-1.1:1.0: USB hub found
[ 3.486464] hub 1-1.1:1.0: 3 ports detected
[ 3.840703] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 3.914945] systemd[1]: System time before build time, advancing clock.
[ 4.039389] NET: Registered protocol family 10
[ 4.042168] Segment Routing with IPv6
[ 4.093499] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.098564] systemd[1]: Detected architecture arm.
[ 4.161890] systemd[1]: Set hostname to <K3sNode2>.
[ 4.339851] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 4.480278] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 4.483072] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.751419] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 4.755381] libphy: lan78xx-mdiobus: probed
[ 4.785845] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.043269] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.058717] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.062605] systemd[1]: Created slice User and Session Slice.
[ 5.066736] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.068800] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.074496] systemd[1]: Listening on udev Kernel Socket.
[ 5.078552] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.085189] systemd[1]: Created slice system-getty.slice.
[ 5.089504] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.093273] systemd[1]: Reached target Swap.
[ 5.902337] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.996763] systemd-journald[133]: Received request to flush runtime journal from PID 1
[ 6.534610] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.537791] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.537809] [vc_sm_connected_init]: start
[ 6.538483] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[ 6.538497] [vc_sm_connected_init]: failed to initialize shared memory service
[ 6.587552] mc: Linux media interface: v0.10
[ 6.644959] videodev: Linux video capture interface: v2.00
[ 6.728556] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.733251] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.797017] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.799223] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.801281] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.861711] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.865328] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.871428] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 6.871723] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 6.873646] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.879392] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[ 7.156775] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.315554] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.421699] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.432541] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.432987] usbcore: registered new interface driver brcmfmac
[ 7.476853] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
[ 7.662127] random: crng init done
[ 7.662141] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.688048] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.720435] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 9.293635] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 9.294698] 8021q: 802.1Q VLAN Support v1.8
[ 9.298707] uart-pl011 3f201000.serial: no DMA platform data
[ 9.318958] Bridge firewalling registered
[ 9.639558] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.032600] 8021q: adding VLAN 0 to HW filter on device eth0
[ 16.101378] Bluetooth: Core ver 2.22
[ 16.101472] NET: Registered protocol family 31
[ 16.101481] Bluetooth: HCI device and connection manager initialized
[ 16.101507] Bluetooth: HCI socket layer initialized
[ 16.101523] Bluetooth: L2CAP socket layer initialized
[ 16.101548] Bluetooth: SCO socket layer initialized
[ 16.118093] Bluetooth: HCI UART driver ver 2.3
[ 16.118111] Bluetooth: HCI UART protocol H4 registered
[ 16.118184] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.118427] Bluetooth: HCI UART protocol Broadcom registered
[ 16.499671] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.499756] Bluetooth: BNEP filters: protocol multicast
[ 16.499782] Bluetooth: BNEP socket layer initialized
[ 44.848695] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
