I reinstalled OSMC and now I can’t enable PVR IPTV Simple Client.
All dependencies installed and activated but Add-on don’t install …
reproduce the issue
upload the log set (all configs and logs!) either using the
After few reboots finally add-on is activated and installed.
So problem is Solved now.
Thanks for the help.
I think this is a bug. I do have same problem.
I have Disabled PVR IPTV Simple Client and now i Can’t Enable it!
Rebooted maybe 5-6 times also made power-off and on its not help.
Shall i update here on this ticket System logs ?
Downloads]$ cat uploadlog.txt | grep "pvr.iptvsimple" | grep "enable"
2021-11-24 19:40:03.921 T:423 DEBUG <general>: CAddonMgr: enabled pvr.iptvsimple
[Downloads]$ cat uploadlog.txt | grep "pvr.iptvsimple" | grep "disable"
2021-11-24 19:40:09.569 T:423 DEBUG <general>: CAddonMgr: pvr.iptvsimple disabled
root@osmc:/boot# paste-log /boot/uploadlog.txt
Unable to upload log. Log file is too large. (21MB)
Thanks.
Shahin
I can’t upload logs, http://paste.osmc.tv/ Doesn’t response. ( 502 Bad Gateway error )
root@osmc:/boot# grab-logs -A -T uploadlog.txt
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/<html>
https://paste.osmc.tv is working here.
Hi @sam_nazarko
Too big file. !
