Hello
Thank you for the endless hours of hard work on this project.
Attempting to install from a USB stick.
Booting from the stick works but from there the installer runs and only returns:
Install failed: could not mount bootfs
Internally the DeskPi Pro has a daughter board mating with the RPi4. It extends both HDMI ports; GPIO; Type-C power and even the TRRS port to make them available at the back of a NUC-style case. At the front the boards adds a power button; two more USB2 ports and a MicroSD card socket that is connected to the Pi’s own. Lastly, there is a secondary board with a SATA interface that is hooked into the RPi by a USB3 double adaptor. This can serve a traditional 2.5" SSD or an M.2 stick via a third adaptor board.
I write all that not to advertise the product but try and explain the situation.
Would be great if I could just use the USB stick as traditional installation medium and set up OSMC on the 2.5" SSD I have connected.
Is this a feasible installation scenario?
Noticed some people have encountered the same error with earlier generation RPi units. At least once fixing the problem by using a different MicroSD card.
In this case, I have no MicroSD card and was hoping to avoid using one with the 2.5" SSD being the primary media.
Any constructive help would be greatly appreciated
