Rsync
Hello,
I was expecting to use rsync to sync my ssd connected to my Vero to my nas device but when I issue the command rsync I get the following:
rsync: command not found
Is rsync not available on Vero even though it is a standard Debian command?
Is it possible to install it?
Regards
Its possible
sudo apt-get install rsync
but you should do
sudo apt-get update
first
Derek
