Ok, So i’ve been using rtorrent with OSMC for quite some time, more specifically I’ve installed it using this script.
I recently upgraded to RPI 3 B+ and learned that that script isn’t beeing maintained anymore, so now I can’t install rtorrent using that method anymore and since the dev of the script is redirecting to his docker container, I thought I’d try that instead.
I think I successfully installed docker using the instructions posted here. and I can successfully run the hello-world example container;
osmc@Sovrum:~$ sudo docker run hello-world
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
61ddb93a5f93: Pull complete
Digest: sha256:f5233545e43561214ca4891fd1157e1c3c563316ed8e237750d59bde73361e77
Status: Downloaded newer image for hello-world:latest
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
(arm32v5)
3. The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading.
4. The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
https://docs.docker.com/engine/userguide/
but I can’t seem to get any life into the kerwood/rtorrent-lxc container.
osmc@Sovrum:~$ sudo docker run --name rtorrent -v /home/osmc/Downloads:/downloads -p 8181:80 -p51121:51121 -d kerwood/rtorrent-lxc
Unable to find image 'kerwood/rtorrent-lxc:latest' locally
latest: Pulling from kerwood/rtorrent-lxc
3d77ce4481b1: Pull complete
a50557b9db64: Pull complete
199a192b00aa: Pull complete
dc2f12a7312e: Pull complete
f8e06d831565: Pull complete
3fa168a22f36: Pull complete
9c30e1687226: Pull complete
ec3949e0cf27: Pull complete
c6842e0a292d: Pull complete
1a980bea8927: Pull complete
def2e01ef2d3: Pull complete
118f88be7507: Pull complete
fa350d88a82e: Pull complete
Digest: sha256:33f4c5992a8f58225a26a3a7b3c48a7afe0ae9fbafdb79c881933565e16e3ca7
Status: Downloaded newer image for kerwood/rtorrent-lxc:latest
c453b27c2b6fd28d5a461b38e55dc35fa30ed334f579e7a8fd56986f2599f303
I can’t access rutorrent web server on http://ip:8181. I know I’m probably doing something wrong, but what?
