Hi–
I’m running out of space on my Vero 4k: only 394M out of 13.8G drive are still available on the disk.
I checked the directories with the largest disk usage via console (sudo du . -h -x --max-depth=1).
On the root level, the directories with the largest disk usage are:
/home(~5.8G or 45% of total disk space) -
/var(~5.6G or 44% of total disk space)
Digging further revealed:
/var:-
/cache(5.5G out of 5.6G)-
/apt(5.5G)-
/archives(5.4G) - (reminder appear to be files (0.1G))
/partial(7.2M) - (majority appear to be files (5.4G))
Is ist safe to delete everything in the /var/cache/apt directory (eg. with apt-get clean / apt-get auto-clean)? Are there any disadvantages?
/home/osmc(5.8G)- /.kodi (5.8G)
/userdata(2.5G)- mostly
Thumbnails(2.2G), so no “problem”
- mostly
/temp(1.9G)- mostly two gz files associated with the Backup AddOn. One stemming from May 2019 (?) and one gz file created this morning. I don’t fully understand why the gz files is still present on the Vero: I can see a backup on the external storage (NAS) with the same timestamp, so, why is it still there (maybe couldn’t be move due to limited disk space, I guess)
- /.kodi (5.8G)
Is it safe to delete everything in the /home/osmc/temp directory (e.g., with rm -r /home/osmc/temp/*)?
Thank you. Stay safe and sound! Markus
