Hello!
I’d like to use DVB2 USB card (PROF 7500) on vero.
Will you consider to add S2-liplianin package to OSMC?
Openelec hasn’t this problem.
Regards.
Hello!
Regards.
Any news??
Am I correctly assume that you refer to this card http://www.linuxtv.org/wiki/index.php/Prof_Revolution_DVB-S2_7500_USB?
If that is the case the drivers should be included in OSMC you only would need to download and install the firmware as described on the above page.
osmc@osmc.hongkong:~$ locate 6100
/lib/modules/4.3.3-1-osmc/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/4.3.3-2-osmc/kernel/drivers/media/dvb-frontends/stb6100.ko
/lib/modules/4.3.3-3-osmc/kernel/drivers/media/dvb-frontends/stb6100.ko
osmc@osmc.hongkong:~$ locate stv09
/lib/modules/4.3.3-1-osmc/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/4.3.3-1-osmc/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/4.3.3-2-osmc/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/4.3.3-2-osmc/kernel/drivers/media/dvb-frontends/stv090x.ko
/lib/modules/4.3.3-3-osmc/kernel/drivers/media/dvb-frontends/stv0900.ko
/lib/modules/4.3.3-3-osmc/kernel/drivers/media/dvb-frontends/stv090x.ko
Maybe you also want to post the output of dmesg for us to verify by giving the URL of dmesg | paste-log
