i have a vero 4 k and the latest update ist installed. if i play sacd iso files with only a 2 Channel stereo signal it works fine. if i play a sacd iso file with included a stereo and a multichannel signal it doesn’t work. there is only undefined noise. it would be great if that worked.
Well if you want support on getting it working you at least would need to upload debug enabled logs and also maybe upload an example to https://videosam.pl/
No need for a log or sample as this is a known limitation. To get multichannel SACD playback you must either be running (currently only beta) Kodi 19 or convert your files to DSF or another supported format. More information can be found in the following thread…
