Sad face after finish playing
Sad face after finished play mkv file. It has probably nothing to do with file type. Sad face happens to me every 4 months approx. It looks like there’s some folder or sd card filling up and after that it crashes. I don’t even update because of that.
https://paste.osmc.tv/vufezukike
Your USB hard drive is completely full, which isn’t ideal. You also seem to be running an old version of OSMC.
but when I tried to update, always get sad face after update…even there was plenty of space on hard drive
Please post a log of the sad face after update and verify that your add-ons and skin are compatible with Kodi v18.
sudo apt-get update
sudo reboot
did I miss something?
https://paste.osmc.tv/ucizelaqus
Yes
sudo apt dist-upgrade
to actually do the update.
You have a file corruption that’s been causing the dist-upgrade to fail.
If it fails again, run the following:
sudo rm /var/lib/dpkg/info/sysvinit-utils.list
sudo apt-get install --reinstall sysvinit-utils
then with a bit of luck the dist-upgrade will work:
sudo apt-get dist-upgrade
logs after update
https://paste.osmc.tv/racekomoze
still sad face loop
We fixed one file corruption and now there’s a second one on a newly downloaded file. While this might have been a network error, it’s more likely to be because the SD card is failing. That would also explain why Kodi keeps crashing.
I recommend that you reinstall onto a new SD card.
Edit: On second thoughts, try this first:
sudo apt-get clean
sudo apt-get update
If that still fails, then go for a new SD card.
Thanks dillthedog
Kodi is running now actually haven’t tested it properly so far.
There were a few errors at the end of installing process.
/tmp/apt-dpkg-install-0jtwfU/45-rbp2-mediacenter-osmc_18.3.0-11_armhf.deb
https://paste.osmc.tv/xofiyisugo
It looks like a bad SD card to me. You need to reinstall on a new card.
Is there any way to export settings including addons?
To backup Kodi settings, either use the MyOSMC backup feature or copy /home/osmc/.kodi to an external drive.
thank you for your help :wink:
Why entertain this?
The SD card has clearly failed.
