Ok, so I’ve been using OSMC on rpi3 for quite some time and it’s been very stable.
A few days ago @sam_nazarko helped me conclude that I indeed seemed to be running on a counterfeit SD card that had given up.
I purchased a new SD card from a from e legit re seller and reinstalled OSMC. Pretty much the same config as before. This time around I didn’t install a no-ip client, also this is a install with the december update!
Here is the dpkg.log
I had to upload the kodi.log since it was very large. It’s been edited for privacy reasons
Now, the SD card contains pretty much the same configuration aside from the no-ip client and an older build of onkyo-eiscp
The crashed are frequent and happen both with http-streams and nfs-streams
Before this I almost forgot OSMC could crash!
