So the vero 4k just ran an update, and after this update, anything that i click on i get a sad face, and then the screen looks exactly how it does after it boots up.
i am not familiar with linux and not really sure what to do here. i got to the login screen and was going to try to reinstall using the commands
ok tried the reinstall, after running those lines, osmc wouldn’t even run. it starts booting with the osmc symbol, then switches to the sad face on a loop.
ran your next 3 lines, and it did the same thing. ran the logs
Jan 14 12:10:06 osmc mediacenter[413]: /usr/lib/kodi/kodi.bin: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /usr/lib/kodi/kodi.bin)
also at which point should i just do a complete rebuild? or is that what the reinstall vero3 statement has done? since i’ve lost my configuration files already
