waited 3 days to update, and was rewarded with a sad face after running the update from within osmc
ran
sudo apt update
sudo apt full-upgrade
the full upgrade installed several packages, and ended with
Unpacking vero3-mediacenter-osmc (19.1.0-16) over (18.9.0-5) ...
dpkg: error processing archive /var/cache/apt/archives/vero3-mediacenter-osmc_19.1.0-16_armhf.deb (--unpack):
trying to overwrite '/usr/share/kodi/addons/visualization.spectrum/addon.xml', which is also in package kodi-visualization-spectrum:armhf 1.1.1-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
osmc@osmc:
so ran
sudo apt remove kodi-visualization-spectrum
then sudo apt full-upgrade was able to complete
