Hallo,
I am new there, but now I need a little help.
We use the OSMC only for torrent and playing films and videos, but after update said face…
Logs:
https://paste.osmc.tv/ujuwomewoq
What can coused? or must make a clean install?
Thank’s for help.
It looks like you have a filesystem corruption.
You can try to fix the specific problem but it’s possible there will be more, in which case a reinstall will be necessary.
To try to fix the immediate problem,in SSH, you need to run:
sudo apt-get update
sudo apt-get install --reinstall rbp-userland-osmc
If that doesn’t help, you’ll need to reinstall.
Thank’s it help. I hope I won’t have problem for the next 2 years
