Yesterday my OSMC updated and I got a sad face.
I tried to reinstall again via SSH but I it still the same.
My logs are here: https://paste.osmc.tv/hepaqobaku
Thanks for your support.
To start with I would try running kodi with default setttings:
sudo mv .kodi kodi.back
It also creates a backup, so you can restore if their isn’t a conflict with your settings & addons with the latest update.
If the above helps, I would restore your settings and addons one at a time; till you find the cause I the issue.
Thanks Tom.
Hi Tom,
I followed your steeps but it give me the same answer .
Do you know what else I can do?
Thanks in advance
You did not move the .kodi directory. There are still addons (Amazon and Plex) trying to run.
