5ghz and my channel settings are set to auto. 2 rigs are working perfectly now on wifi with passthrough audio receivers, but third rig I cant get any audio post update. Its a SPIDF optical connected sound bar. Audio settings all look correct… I cant even get the Kodi click sounds.
Check if you have disabled stereo upmix.
Ok, just keep in mind that when they change to above 100 you might have problem
Just to clarify it’s a sound bar connected to TV not to vero4k. Stereo up mix is disabled, channels set to 2.0. I tried several settings to no avail. AppleTV also connected to same tv works fine so I know the soundbar setup is solid
So Vero to TV via HDMI and then TV to Soundbar via SPDIF?
Upload debug logs then we can check if we see anything.
