Sad face, boot loop after upgrade attempt Vero 4k+
Hello everyone,
I tried upgrading my Vero 4k+ today through MyOSMC but after the reboot I kept getting a sad face and eventually a reboot.
I SSH’d into the vero to update it manually and got this error:
You might want to run 'apt --fix-broken install' to correct these.
 armv7-network-osmc : Depends: armv7-bluezalsa-osmc but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
So naturally I tried “sudo apt --fix-broken install” next but unfortunately I got this message:
dpkg: error processing archive /var/cache/apt/archives/armv7-bluezalsa-osmc_3.1.0-2_armhf.deb (--unpack):
 trying to overwrite '/etc/dbus-1/system.d/bluealsa.conf', which is also in package armv7-bluez-alsa-osmc 1.0.5
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
All help will be appreciated.
EDIT:
I fixed it by doing:
sudo dpkg -r armv7-bluez-alsa-app-osmc
sudo dpkg -r armv7-bluez-alsa-osmc
sudo apt-get install armv7-bluezalsa-osmc
Just quoting so we can tick as solved
I had exactly the same problem/error message. Thank you for working out the fix and posting it!!
I have a sad face loop on mine as well and can’t ssh into the box. Its complaining about the conman service on the screen. How should I proceed?
