I am a tinker in my skins and sometimes when i change a lot a get a sad face, previously the sad face would auto reboot the vero, but since a few updates it doesn’t to that anymore, and i have to reboot through ssh. Is there something changed in this process?
tom
I am already on the latest update from bullseye.
grahamh:
Try updating
Either Sam didn’t push that or it didn’t work because I still have the issue on both my test builds.
In the meantime if you push any button on your remote it should then come back after a few seconds. At least it has been for me.
Should only be an issue on older 4.9.269 test builds which aren’t Bullseye based. The 4.9.113 kernel shouldn’t be affected.
Do you get this result?
osmc@vero4kp2:~$ grep read /usr/bin/mediacenter
read -n 1 -s -t 1 dump </dev/tty1
read -n 1 -s -t 10 key </dev/tty1
I have this issue as well. Sad face stays. Requires a button press. Latest bullseye.
The fix is now pushed. You might have to wait an hour or so (from when I’m typing this) before you’ll be able to get it.
Thanks for fixing it so fast!
