Last time I’ve observed that kodi is not able to start. I’m still getting sad face on my screen. SSH and other services are working. Unfortunatly I cannot figure out what was happened.
Here are the logs, I hope that you can help me with that. I don’t want to reinstall whole system.
Well assuming you have an issue with your addons.
Try to move kodi folders and see if it starts then.
If all ok then start to move the kodi folder back and check stuff that you recently installed.
True that seems to be one of your problems.
But the bigger is quite a few packages that you have installed and worse you ran apt-get upgrade which is know to brake systems.
So my advice is to reinstall clean
This is a debian system, that is how its supposed to work. If you seriously cannot run normal debian commands, then you have done it wrong. If something about OSMC is broken by another dependency on the system, the package should be properly made to indicate as such.
It does – but when you run apt-get upgrade, you are not allowing APT to install new dependencies, you are only requesting existing ones be upgraded, which is why you get problems.
