hello,
I have been happily using osmc since 2 years ago on a Rpi3.
sometimes when I manually update I have issues until I make it run properly, I may have a special config or maybe some plugins that it does not like much.
anyway, I updated yesterday and I keep having the sad face loop.
I have tried reinstalling the packages that it listed as upgraded/installed yesterday in /var/log/dpkg.log, with no luck.
I have tried moving my /home/xxx/.kodi folder elsewhere, with no luck.
I have been lurking the forums for some extra uncovered knowledge that could help me, but I can no longer find anything that may help me, sad face.
the logs are in http://paste.osmc.io/uxetusibej
could anyone give me an idea on how to fix it?
thank you guys!
First always provide full logs with grab-logs -A
Secondly you have run apt-get upgrade in the past which might have put your system in an unstable state.
Suggest a clean new install
NEVER use apt-get upgrade. Only use apt-get dist-upgrade.
Thank you for your answers guys.
I think I did a ‘grab-logs -a’, not sure if results are the same as in ‘-A’.
Concerning -upgrade, it will only tell me i have to do -dist-upgrade instead, so even if I missed that, system forced me to do it correctly.
And about the clean install… I am avoiding it! I customised it a little bit, I would rather prefer investigating a little bit more than having to redo all the
My installs, configs and such.
I will do a grab-logs -A’ asap.
Ok so I got the logs at http://paste.osmc.io/kirivedava.
Let me know if you find something that I missed.
