Hi all,
I updated my osmc yesterday, and it got stuck in a loop where it boots to a sad face and reboots repetitively.
Logs have been pasted to: https://paste.osmc.tv/uhotutoqew
I don’t think I have too many customisations going on, except maybe some skins. I don’t think I’ve added/changed anything recently.
Can someone please let me know what I did wrong?
Many thanks
You have the experimental staging repository enabled. You should disable this and downgrade.
Hi @sam_nazarko, thanks for the super-quick reply.
Just to be sure, has that come from the line:
deb http://apt.osmc.tv bullseye-devel main in /etc/apt/sources.list?
and it should be changed to include bullseye in place of bullseye-devel?
I hate to say it, but: btw I use arch. I only mention this to apologise for my unfamiliarity with deb package management
Yes, and then downgrade MESA
Done, and done.
Many thanks, @sam_nazarko, libglapi-mesa:armhf and rbp2-mesa-osmc are now more stable, it appears
Do I add ‘SOLVED’ to the title? I don’t see it with a quick scan at other posts.
Thanks again
No need, there is a “Solution” button that you can use on one of the answers which I have now done for you
